Dzisiaj jest czw mar 26, 2026 8:39 am
 Tytuł: prosba o VIN!!!
Post: czw sie 12, 2004 10:55 pm
Koega dalej szuka W124. Dzieki za wczesniejszy VIN dzieki Wam go nie kupil bo ten egz to byl Szczepan - nr. motorynki sie nie zgadzaly. Ma na oku nastepnego
jego VIN to: WDB 1241281B847546
z gory dzieki
MILOSH
ex. W201 2.0D 1987
ex. MB S124 250D 1990
ex. W124 220E 1993
ex. W202 C180 1994
ex. W210 E290 TD 1996
W124 250D 1988
W123 240D 1981
BMW E39 520i 1997
BMW E34 520i 1991
BMW E38 728iA 1998
Post: czw sie 12, 2004 11:00 pm
VIN WDB1241281B847546
Model 250 D TURBO
Chassis 1241281B847546
Engine 602962 10 025128
Transmission 717437 06 208868
Order 0 2 543 28026
Lights BOSCH
Wiper BOSCH
Cab 09637
Dealer Italy (543)
Interior cloth black (061)
Paint
199 metallic blue-black
Options
240 outside temperature indicator
second spare wheel
280 trunk set, 3-piece
steering wheel (400 mm dia.) and gearshift lever in leather trim; on W202 390 mm dia.
341 additional lamp
additional turn signal lamps for Japan, Denmark, Italy and national code 837
special version for export to cold countries
442 airbag in steering wheel
bumper, rear, with guards
466 central locking system
461 + 464
462 + 463
570 folding armrest front w202/210 stowage box front with armrest
front folding armrest w202 - housing at front with armrest
587 front folding armrest
single seats with folding armrest
automatic climate control and electric window lifters (front doors)
593 headlamp flasher and turn signal lamps - italy
headlamp flasher and turn signal lamps, front, crystal clear
heat-insulating glass, rear window pane
heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip
731 wood trim, burred walnut root
877 reading lamp in the rear
w123 230c 78', w123 200d 82' ,w124 300Ce 88', W211 E500 4matic 2004' ,W211 270CDI 2002'
