Dzisiaj jest pt lip 31, 2026 3:38 pm
Post: pn mar 15, 2010 12:59 pm
Hej, może ktoś z was dysponuję informacją ile waży dokładnie Mercedes 220B cabrio? Jest mi bardzo potrzebne a w necie nie mogę zlokalizować tej informacji.
W107 450SL
Post: pn mar 15, 2010 1:03 pm
nie wiem czy oto Ci chodzi..??
Type 220 S Cabriolet
Name 220 S Cabriolet
Name Mercedes-Benz type 220 S Cabriolet
Short name 220 S Cabriolet
Model W 180 II
Production 07.56 - 10.59
Number produced 2.178
Comments concerning the production period
Prices 21.500,00 DM
Wheelbase 2700 mm
Track rear/front 1430/1470 mm
Length 4700 mm
Width 1790 mm
Height 1530 mm
Smallest turning circle 10,7 m
Chassis weight
Max. total weight 1790 kg
Max. front axle weight 840 kg
Max. rear axle weight 950 kg
Max. load 405 kg (with Hydrak: 390 kg)
Max. trailer weight braked 1200 kg
Max. trailer weight unbraked 740 kg
Weight empty 1385 kg (with Hydrak: 1400 kg)
According to guideline DIN 70020 (with fuel, spare wheel and tool equipment)
Operating method four-stroke Otto
Configuration front, parallel; upright
Type M 180 III / 180.924
No. of cylinder/configuration 6 / in line
Bore x stroke 80 x 72,8 mm
Total displacement 2195 ccm (tax classification: 2171 ccm)
Compression ratio 7,6; since 08.57: 8,7
Crankshaft bearing 4
Output 100 hp at 4800 /min; since 08.57: 106 hp at 5200 /min
Maximum torque 16,5 mkg at 3500 /min; since 08.57: 17,5 mkg at 3500 /min
No. of valves/configuration 1 intake, 1 exhaust / overhead
Valve operation top camshaft
Camshaft drive duplex roller-type chain
Mixture formation 1 register-downdraught carburetter Solex 32 PAJTA
Cooling water cooling / pump; 11,3 l water
Lubrication pressure circulation lubrication / 6 l oil
Electric system 12 V
Battery 56 Ah / in the engine compartment
Dynamo 160 W
Starter motor electrical / 0,8 PS
Ignition battery ignition
Fuel tank in the rear / 64 l
Fuel supply diaphragm pump
Driven whells rear wheels
Power transmission divided cardan shaft
Frame desing floor assembly / self-supporting all-steel body
Wheel suspension front double wishbone
Wheel suspension rear single-joint swing axle
Suspension front coil springs, torsion bar stabilizer
Suspension rear coil springs
Damper hydraulic telescopic damper
Steering recirculating-ball steerg.
Steering transm ratio 20,8:1 / 4 steering wheel turns
Breaking system braking system
Breaking system hydraulic, with vacuum-operated brake servo unit, effective on front- and rear wheels ; drum brakes front and rear
Parking breake parking brake
Parking breake mechanical, effective on rear wheels
Diamatre brake drums front / rear: 230 mm
Wheels sheet steel-disc wheels
Wheels rims drop centre rim 5 K x 13
Tyres 6,70-13 Sport
Skrzynie biegów tego modelu (gearbox and performance):
"Ponton"-Coup�s and~-Convertibles, types~220 S and 220 SE (W 180, W 128)
Gearbox 4-speed gear shift
Availability Series
Shifting Gear shift
Clutch Single-plate dry clutch
Type of gearbox Pinion change gear
Synchromesh gears I - IV
Gear transmission I. 3,52; II. 2,32; III. 1,52; IV. 1,0; R. 3,29
Differential ratio 4,10
Maximum speed 160 km/h
Accelerations 17 s
Comments Acceleration with shifting through from 0 - 100 km/h; loaded with 2 persons
Fuel consumption 10,7 l
acc. to guideline DIN 70030, ascertained at 3/4 of max. speed, maximal 110 km/h, unter Zuschlag von 10 %
Availability by request (from 08.57)
Shifting Gear shift
Clutch hydr.-aut. clutch "Hydrak"
Accelerations 17 s
Fuel consumption 10,9 l
MB S124 280TE 96r.-BeetrooT
Post: pn mar 15, 2010 1:16 pm
niestety ty podałeś dane następnego modelu, mi chodzi o 220B cabrio z początku lat 50-tych. Generalnie mam trochę opisów ale nigdzie nie mam wagi;(
W107 450SL
Post: pn mar 15, 2010 1:18 pm
ZORTOX pisze:
Model W 180 II
Chodzi o Cabrio (A czy B??) W 187, czyli jakby obecna s-klasa w cabrio produkowana w latach 51-55. Masa wlsna kabrioleta (A i B) to 1440kg (wedlug Wikipedia)
PS
Ktos tu sie chyba czai na auto moich marzen (cabrio A) ;) ??
Ostatnio zmieniony pn mar 15, 2010 1:24 pm przez Stomek, łącznie zmieniany 1 raz.
Post: pn mar 15, 2010 1:21 pm
chodzi o B niestety;(
W107 450SL
Post: pn mar 15, 2010 1:25 pm
Juz sie czailem kiedys na tego w mazowieckim, ale stwierdzilem ze jak ma byc A to A i trzeba pocierpiec jeszcze jakis czas, zeby w koncu miec tego wymarzonego [zlosnik]
Post: pn mar 15, 2010 1:29 pm
ten z Mińska Mazowieckiego to niewykończony projekt i już skundlony, brakowało trochę gratów a część już po amerykańsku przerobione. Ja czaję się na w pełni oryginalny 220B jeszcze nie ruszany, ale zobaczmy co z tego bedzie
W107 450SL
Post: pn mar 15, 2010 1:35 pm
richie pisze:
.... jeszcze nie ruszany, ale zobaczmy co z tego bedzie
I na takiego tez ja sie kiedys przyczaje [zlosnik] , ale A.
Post: pn mar 15, 2010 1:38 pm
coraz mniej tych nie ruszanych a coraz wiecej powyzej 100k. eur po renowcji w kinle itp.
W107 450SL
Post: pn mar 15, 2010 1:41 pm
Jakos da sie rade, najwazniejsze ze wydatek jest/bedzie zaakceptowany przez szefowa
Post: pn mar 15, 2010 1:59 pm
ok znalazłem takie info:
dry weight: 1440kg.
loaded weight: 1785kg.
no i o co w tym chodzi?
W107 450SL
Post: pn mar 15, 2010 2:54 pm
richie pisze:
dry weight: 1440kg.
Wrzucilem mase wlasna juz w pierwszym swoim poscie- 1440kg. Dopuszczalna masa calkowita to 1785kg
Post: pn mar 15, 2010 3:22 pm
no to kazcko bo laweta którą mam wypożyczyć ma ładowność 1540kg:)
W107 450SL
Post: pn mar 15, 2010 3:33 pm
Pochwal sie nabytkiem, jak przytaszczysz :)
