Dzisiaj jest śr paź 07, 2026 5:41 am
Nowy temat  Odpowiedz w temacie  [ Posty: 1261 ]  Przejdź na stronę Poprzednia 1 2 3 4 5 … 85 Następna
Post: wt cze 30, 2009 10:19 pm
Numer GG: 411522
VIN WDB1240261A859505
Model 260 E
Chassis 1240261A859505
Engine 103940 10 023867
Transmission 717430 01 131644
Order 0 8 287 91678
Delivery date 26.09.88
Dealer authorities sales (287)
Interior fabric gray or alpaca gray (078)
Paint
355 diamond blue metallic (1984-1990, с 1994)
Options
280 steering wheel (400 mm dia.) and gearshift lever in leather trim; on W202 390 mm dia. (с 01.05.1984)
412 electric sliding roof with tilting device (с 01.07.1983)
430 headrests in the rear (с 01.01.1977)
452 two-tone horn (с 01.01.1963 по 28.02.1993)
506 outside rear view mirror, left and right, heated (electrically adjustable on the right) (l.h.d.) (с 01.10.1983 по 31.03.1989)
outside rear view mirror, right, convex, taxi export version
534 antenna, mechanically operated, without radio set (с 01.01.1963 по 30.11.1990)
543 sun visor with vanity mirror, illuminated, left and right (с 01.11.1978)
563 front seats, left and right, reinforced (с 01.04.1970)
583 electric window lifters (front doors) (с 01.04.1970)
590 heat-insulating glass, all-around, heated rear window pane (laminated glass), Germany
green heat-insulating glass all round, heated rear window, laminated safety glass - Germany (с 01.01.1972)
611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.1978)
620 emission control system
vehicles with catalyst technique (с 01.03.1985)
645 M+S tires (с 01.10.1963)
673 high-capacity battery (с 01.01.1964)
682 fire extinguisher (с 01.04.1970)
812 rear-mounted loudspeaker (с 01.11.1974)
Post: wt cze 30, 2009 10:26 pm
Sorry , nałożyłem się z maxtro [zlosnik]
C140 5.0
Post: wt cze 30, 2009 11:53 pm
Chciałbym prosic o rozkodowanie mojej 123 o nastepujacym numerze VIN: 123123 12 040897
Mam tez ksiazke serwisowa w ktorej sa rozne numerki jak np 737 Lack, wiec odkrylem juz ze samochod kiedys byl bialy :) no i jeszcze nr 12 w Vinie ktory chyba oznacza automat ? jest tez "nr 101 przy Ausst." wydaje mi sie ze to moze byc ausstatung=wyposazenie, ale nie wiem za bardzo gdzie moge sprawdzic czym charakteryzuje sie wersja z nr 101 :) przede wszystkim chciałbym sie dowiedziec jakie bylo wnetrze pojazdu (fotele).
i jeszcze pytanko na koniec, gdzie moge znalezc zderzaki w wersji amerykanskiej do mojego pojazdu... :) szukam, szukam i nic :)
Pozdrawiam <br>Dodano po 1 godzinach. 21 minutach.:<br> i jeszcze dodaje dwie fotki, jedna ksiazki serw. i jedna blaszki pod klapa :)
W 123 240D '77 USA
Post: czw lip 02, 2009 12:37 am
Austattung, czyli material i kolor wnetrza: 101
Kolor nadwozia: 737
401 - pojedyncze fotele z przodu
411 - mechanicznie odsuwany dach
426 - wspomaganie kierownicy i automatyczna skrzynia biegow z dzwignia w podlodze
467 - centralny zamek oraz zegary i przelaczniki z napisami w jezyku angielskim
491 - wersja dla USA
515 - radio Becker Europa MW/USW, dla USA
524 - dodatkowa ochrona lakieru
542 - schowek zamykany na klucz
575 - podlokietnik miedzy przednimi fotelami i lewy zaglowek
580 - klimatyzacja Behr
593 - szyby atermiczne, dookola, szyba czolowa z zielonym paskiem, szyba tylna ogrzewana, pojedyncza, ze szkla hartowanego
636 - eliminacja trojkata ostrzegawczego
668 = 662 + 666
662 - 10 litrow paliwa
666 - 10 litrow paliwa i rodzaj opakowania (przygotowania do transportu) VE II
Post: czw lip 02, 2009 6:36 pm
Dziękuje bardzo :) <br>Dodano po 4 godzinach. 59 minutach.:<br> a czy da sie gdzies zlokalizowac jaka byla podsufitka? bo jest bezowa, tak samo jak elementy na gorze przy szybie. A jezeli fotele byly czarne to dosc nietypowe zestawienie :)
W 123 240D '77 USA
Post: pt lip 03, 2009 12:08 am
Samochod pierwszoseryjny wiec podsufitka dziurkowana, w kolorze bialym a cala reszta (daszki przeciwsloneczne, oslony slupkow, panel nad szyba) czarne z pierwszoseryjna faktura.
Post: pt lip 03, 2009 8:09 am
Witam , nareszcie słońce świeci. Mam dziś dwa ciekawe numery VIN:
11401110102222 oraz WDB126022100053642 , pozdrawiam i dziękuję. <br>Dodano po 4 minutach.:<br> Datacard for VIN WDB12602210005364 is not found
1) VIN was misspelled in the request form;
2) VIN was erroneously read from vehicle body or documents;
3) VIN is not of an original vehicle and was forged by criminals;
4) The vehicle was produced in late 2005 or 2006, and is not included yet in our database <br>Dodano po 3 minutach.:<br> VIN WDB12602210053642
Model 280 SE
Chassis 12602210053642
Engine 110989 10 001721
Transmission 716007 00 015346
Order 0 1 229 04663
Approx. year 1981
Lights BOSCH
Cab 22084
Dealer Stuttgart branch (229)
Interior Unknown code (031)
Paint
735 astral silver metallic (с 01.01.1972 по 31.12.1990, с 1994)
Options
504 outside rear view mirror, right, electrically adjustable (с 01.11.1978 по 29.02.1986)
outside rear view mirror, right, electrically adjustable (l.h.d.)
taxi version, f.r.g, and outside rear view mirror on the right
514 Becker radio Europa (LW/MW/SW/USW)
Becker radio Europa LW/MW/USW (с 01.01.1963 по 30.09.1983)
656 Michelin tires (с 01.08.1965 по 31.10.1989) <br>Dodano po 1 minutach.:<br> taxi version qurqa
Post: pt lip 03, 2009 10:36 am
Bodzio pisze:
taxi version qurqa
Bodzio, wez nie rob scen. Jest przeciez napisane wyraznie:
504 outside rear view mirror, right, electrically adjustable (с 01.11.1978 по 29.02.1986) czyli prawe lusterko regulowane elektrycznie.
Musze przyznac, ze tak wypasionego egzemplarza, w dodatku w najpiekniejszej kombinacji kolorow jaka talko moze byc, to juz dawno nie widzialem... :P.
Bodzio pisze:
11401110102222
250 z silnikiem M130.923 (2,8 l), gdzies w srodku drugiej serii, skrzynka mechaniczna, kierownica tak jak lubisz ;).
Post: pt lip 03, 2009 12:23 pm
kielbik pisze:
Bodzio pisze:
taxi version qurqa
Tak, pierwszy właściciel dużo musiał zapłacić za zdemontowanie ABS, elektrycznych szyb, klimatronika, podgrzewanych siedzeń, zastąpienie skóry czymkolwiek, wymontowanie centralnego zamka, wycieraczek na reflektory i nie wiem czego jeszcze co było w standardzie.
kielbik pisze:
Bodzio pisze:
11401110102222
Tak, czerwono-kremowy pickup 300D z białą kierownicą.
Post: pt lip 03, 2009 11:45 pm
Bodzio pisze:
Ty jesteś z tych, którzy wierzą, że jak na klapie jest S, to już pana Boga za nogi złapali, bo wszystkie kody są "w standardzie"?
Post: ndz lip 05, 2009 6:52 am
(me: how) pisze:
Bodzio pisze:
Podpowiedz mi, O! Guru!, gdzie na klapie powinno być S, bo za zdemontowanie tego S też musiał dopłatę zrobić, ale we własnym zakresie mógłbym niedrogo sobie dostawić.
 Tytuł: vin
Post: ndz lip 05, 2009 11:51 am
Proszę o rozkodowanie numer VIN :)
107022 12 003259
Z góry dzięki wielkie!
http://www.carcovershield.pl/ ochrona przed korozją
Post: wt lip 07, 2009 12:20 am
W odpowiedzi na ten post:
Numer nadwozia: 114.022-12-021361;
Numer silnika: 114.980-12-011616;
Numer skrzyni biegow: 060893;
Data przekazania: 05.04.1972;
Kolor nadwozia: 834 - zielony metalic (od 01.01.1963 do 31.12.1968, od 1994);
Kolor i material tapicerki: 005 - pergament (kolor kremowy), tkanina;
Uklad przednich siedzen: 401 - pojedyncze fotele (od 01.01.1962 do 31.01.1978);
Reflektory: Hella;
Ogumienie: Phönix;
Numer kluczylka: Z xxxxx
Wyposazenie dodatkowe:
248 - tylna szyba ogrzewana elektrycznie, ze szkla klejonego (od 01.01.1964 do 30.11.1991)
254 - eliminacja napisu "automatic" (od 01.11.1964 do 31.12.1972)
410 - elektrycznie odsuwany dach (od 01.03.1965 do 29.02.1988);
426 - wspomaganie kierownicy i automatyczna skrzynia biegow, dzwignia zmiany biegow w podlodze (od 01.10.1964 do 29.02.1986)
466 - centralny zamek (od 01.04.1970 do 31.10.1993)
533 - uklad odklocania bez montazu radia (od 01.01.1967 do 29.02.1984)
573 - zaglowki, lewy i prawy (od 01.01.1963 do 31.08.1977)
618 - reflektory halogenowe (ruch prawostronny) (od 01.04.1970)
630 - opony z opasaniem promieniowym (od 01.03.1966 do 31.10.1974)
673 - akumulator o zwiekszonej pojemnosci (od 01.01.1964)
Post: wt lip 07, 2009 9:13 am
Proszę o pomoc w rozkodowaniu VIN: 12312310161716.
Auto podobno z 1980 roku ale wnętrze jest z 3ciej serii i ma dyfuzory na tylnych słupkach co również występowało w 3ciej serii dopiero. (Mogę się mylić).
Z góry dziękuję.
Post: wt lip 07, 2009 11:15 am
Proszę....
VIN WDB12312310161716
Model 240 D
Chassis 12312310161716
Engine 616912 10 133085
Transmission 007193 64
Order 0 9 513 19597
Approx. year 1979
Lights HELLA
Cab 54077
Dealer Belgium (513)
Interior Unknown code (034)
Paint
623 light ivory (T) (с 01.01.1972 по 1993)
Options
411 mechanical and hydraulic sliding roof (с 01.10.1965 по 31.10.1993)
422 mercedes-benz power steering (с 01.01.1963 по 29.02.1986)
438 automatic (self-reeling) safety belts front left and right
safety belts, front, rear and central
elimination of rear safety belts
466 central locking system (с 01.04.1970 по 31.10.1993)
502 outside rear view mirror, on the right (с 01.01.1963 по 31.03.1983)
593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972)
665 Do not fuel vehicle - :-?
C140 5.0
