Dzisiaj jest śr wrz 30, 2026 2:59 am
 Tytuł: Vin kod 300
Post: ndz lut 03, 2008 9:57 am
VIN WDB1241901F227613
Model 300 TD
Chassis 1241901F227613
Engine 603912 10 081913
Transmission 717433 06 143523
Order 0 2 225 00778
Approx. year 1992
Lights BOSCH
Wiper BOSCH
Dealer Mannheim branch (225)
Interior cloth brazil (063)
Paint
702 smoke silver metallic (с 01.01.1983)
Options
240 outside temperature indicator (с 01.03.1982)
260 elimination of model designation on rear lid (с 01.05.1968)
291 airbag for front passenger
airbag for driver and front passenger (с 01.07.1987 по 30.09.1993)
airbag for driver and front passenger (if driver airbag standard - then only for passenger)
300 storage box in front tray (с 01.05.1988)
412 electric sliding roof with tilting device (с 01.07.1983)
531 automatic antenna (с 01.01.1963)
541 double roller blind used as luggage and passenger guard (с 01.01.1980)
550 trailer coupling (с 01.03.1965)
570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
591 heat-insulating glass, all-around, heated rear window pane, (single-sheet safety glass), Germany
green heat-insulating glass all round, heated rear window, single pane safety glass - Germany (с 01.01.1972)
620 emission control system
vehicles with catalyst technique (с 01.03.1985)
673 high-capacity battery (с 01.01.1964)
682 fire extinguisher (с 01.04.1970)
750 Becker radio Europa 2000 vk (с 01.06.1990 по 31.03.1994)
Prośba do znawców tego tematu co to jest do diabla kod 300 translator przetlumaczyl to jako/magazynowanie pudło przed taca/ :o
S 124 300D 92 r.-girasol www.psicholog.eu szkolenia psów Jelenia Góra
Post: ndz lut 03, 2008 10:02 am
To jest chyba schowek między siedzeniami przednimi, taki z roletą
Skoda Fabia Combi 1,4TDI
Post: ndz lut 03, 2008 10:33 am
BoogieCE pisze:
A wyglada tak:
S123 300TD
Post: ndz lut 03, 2008 11:12 am
Dzieki.Jak wygląda ten schowek to wiem,bo taki tez mam [zlosnikz] Nigdy nie analizowałem swojego Vinu i jakos dzisiaj mnie naszło aby trochę pogrzebac w tym temacie.Wszystko było jasne ale tlumaczenie przez translatora kod 300 rozwaliło mnie i za cholere nie mogłem sie kapnąc o co chodzi.Dzieki za podpowiedz
