Dzisiaj jest pt mar 27, 2026 4:22 am
Post: wt kwie 24, 2007 11:15 am
szukałem szablonu ale chyba zostal odwieszony i gdzieś mi go wcieło .
12305322019065
Post: wt kwie 24, 2007 11:28 am
VIN WDB12305322019065
Model 280 CE
Chassis 12305322019065
Engine 110984 22 074790
Transmission 02 126451
Order 0 0 537 61457
Approx. year 1980
Dealer Great Britain (537)
Interior Unknown code (935)
Paint
940 marine blue (T) (с 01.01.1979 по 31.12.1981)
Options
286 luggage nets on front seat backrests (с 01.01.1962)
320 additional plate and rear seat bench stop for great britain (с 01.03.1967 по 31.07.1980)
339 front seat, left lower (с 01.03.1967 по 29.02.1996)
340 front seat, right, lower (с 01.03.1967 по 28.02.1986)
410 electric sliding roof (с 01.03.1965 по 29.02.1988)
420 automatic transmission, floor shift (с 01.01.1963)
432 headrests in the rear and elimination of front and rear safety belts (с 01.01.1977 по 28.02.1986)
headrests in the rear, elimination of automatic (self-reeling) safety belts
440 tempomat (cruise control) (с 01.09.1975)
467 central locking system and instruments with english lettering (с 01.04.1970 по 31.10.1993)
524 paintcoat preservation (с 01.01.1964)
570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
583 electric window lifters (front doors) (с 01.04.1970)
593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972)
613 lamp unit, asymmetrical, l.h. traffic (с 01.02.1963)
656 Michelin tires (с 01.08.1965 по 31.10.1989)
666 10 liters of fuel and mode of packing VE II (с 01.12.1965 по 31.08.1986)
"...Oh Lord, won’t you buy me a Mercedes Benz ?
My friends all drive Porsches, I must make amends.
Worked hard all my lifetime, no help from my friends,
So Lord, won’t you buy me a Mercedes Benz ?..."
Witam kolegę,
rozkmiliwszy - wklejam [zlosnik]
Model 280 CE
(...) już nie będę dalej zaśmiecał [zlosnik]
Dane ze strony: http://www.mbclub.ru/mb/vin/?lng=eng
A tu masz mniej interaktywny klucz: http://www.w114-115.org.pl/jomla/content/view/105/77/
Przykłady kolorów i wzorów tapicerek: http://www.astralsilber.de/
Pozdrawiam [cool]
W114 250C 1971 USA
Post: wt kwie 24, 2007 11:41 am
Dzięki Tomek . tak sie właśnie zastanawiam nad tym coupe http://cgi.ebay.co.uk/1980-MERCEDES-280 ... dZViewItem
bo transport to juz nie problem a pojezdziło by sie [zlosnikz]
chymon właśnie tego klucza szukałem 8) dzięki .
Post: wt kwie 24, 2007 11:46 am
Dokleisz PL z gwiazdkami na tablicę rejestracyjną i śmigasz jako rodowity mieszkaniec okolic Gdańska - taki Pruszczanin np [zlosnik] [zlosnik]
W114 250C 1971 USA
Post: wt kwie 24, 2007 12:22 pm
z zewnątrz jak bliźniaczka mojej :lol: tylko w środku trochę lepiej [szalone]
[b]116 280S / 673 + 303[/b]
Turchese Farfalla - 126 '77
Post: wt kwie 24, 2007 7:01 pm
oz kurde to jeszcze taniej niz mój,i na zdjeciach ladniej wyglada...
Post: śr kwie 25, 2007 12:31 am
jugo500 pisze:
12305322019065
jugo500 pisze:
Widze, ze robi sie ruch w angolach :)
SKOWRON pisze:
buckswizz pisze:
Panowie, czytac, czytac...
nterior is bad and body has rust
only problem when starting is it will start out of park
will need to be trailerd away
Ale swoja droga samochody w kiepskim stanie sa w Anglii naprawde tanie, w Niemczech nawet kupa zlomu wyciagnieta ze stawu sprzeda sie na eBayu za min 500-800 €
Post: śr kwie 25, 2007 12:07 pm
Tomek pisze:
Ciekawa opcja... ktoś fantazję miał. Ciekawe czy to też było za dopłatą...
el_diablo
c123 - sprzedany
s124 - rozbity
Post: śr kwie 25, 2007 12:25 pm
kielbik masz racje . od jakiegos czasu na ebay.de złomy chodza za więcej niz na złomie :/ nie wiem czy aurat kupie tego niebieskiego ,czy dam troszkę więcej i kupie w lepszym stanie , ale UK jest bardzo obiecującym rynkiem [zlosnik] natomiast jeżeli chodzi o Niemcy to juz tylko mega szczęście ci pomoże :(
Post: śr kwie 25, 2007 2:40 pm
w sumie w Anglii klasyki w dobrym stanie tez sa drogie,ale jesli cos jest w takim stanie jak w/w to da sie cos znalezc w miare tanio-choc to tanio jest tez bardzo umowne...
Post: śr kwie 25, 2007 5:40 pm
buckswizz pisze:
no nie przesadzaj: 122 £, czyli niecale 200 € - sprzedasz felgi, zderzaki, pare drobiazgow i juz masz dwa razy tyle (nawet jak uwzglednisz koszty transportu). W Niemczech nie byloby szans na taki zakup, jak piec lat tu siedze jeszcze sie taka okazja nie zdarzyla.
Post: śr kwie 25, 2007 6:40 pm
pewnie masz racje...
p.s doszly zdjecia?
