Dzisiaj jest czw lip 16, 2026 1:18 am
Post: śr gru 02, 2009 12:21 am
To mój pierwszy post na tym forum, ale czytuje je od ponad roku.
Już nie mogłem wytrzymac.
Co sądzicie o tej Gwiazdce?
http://allegro.pl/item832827772_mercede ... _taki.html
Po rozmowie telefonicznej uzyskałem to:
VIN WDB1243931F297208
Model 300 TD TURBODIESEL 4 MATIC
Chassis 1243931F297208
Engine 603963 12 004427
Transmission 722344 04 013461
Order 0 4 219 02302
Approx. year 1994
Lights HELLA
Wiper BOSCH
Dealer Hamburg branch (219)
Interior leather black or anthracite (261)
Paint
721 onyx grey metallic (с 01.01.1994)
Options
240 outside temperature indicator (с 01.03.1982)
291 airbag for front passenger
airbag for front passenger (с 01.10.1993)
airbag for driver and front passenger (if driver airbag standard - then only for passenger)
300 storage box in front tray (с 01.05.1988)
412 electric sliding roof with tilting device (с 01.07.1983)
440 tempomat (cruise control) (с 01.09.1975)
515 Becker radio (AM/FM - USA)
radio MB Classic with traffic news decoder (VK) (с 01.07.1992)
541 double roller blind used as luggage and passenger guard (с 01.01.1980)
553 trailer coupling and anti-theft warning system (с 01.11.1978)
570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
586 Behr air conditioner, and electric window lifters (front and rear doors) (с 01.04.1970)
593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972)
611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.1978)
620 emission control system
vehicles with catalyst technique (с 01.03.1985)
652 8-hole light alloy rims (с 01.01.1990)
673 high-capacity battery (с 01.01.1964)
731 wood trim, burred walnut root (с 01.08.1980)
844 folding seat bench in loading compartment, reverse to direction of travel (с 01.10.1977)
866 Technical changes of modelling year 1995 (с 01.01.1994 по 19.10.1997)
873 seat heater for left and right front seats (с 01.02.1984)
885 locking system with infrared remote control and immobilizer (с 01.10.1993)
880 - with immobiliser
oraz cenę: 16k
Czy 4matic traktowac należy jako plus, czy może minus?
Pan wspominał, że w aucie wszystkie bajery działają, jest zadbane-2 lata w PL.
Ostatnio zmieniony śr gru 02, 2009 5:29 pm przez skorpion986, łącznie zmieniany 1 raz.
Post: śr gru 02, 2009 8:54 am
Ładna, dobrze wyposażona, aczkolwiek według mnie, patrząc na pierwsze dwa zdjęcia, można przypuszczać że przodem zaliczyła dzwona. Mogą o tym świadczyć nierówne szczeliny między lampami a maską i ogólnie kiepskie spasowanie elementów przodu. Niech koledzy mnie poprawią jeśli się mylę :)
V945 2.3T 97'
Ex: V945 93' "Knudsen"
Ex: W123 240D 78' Englischrot
Post: śr gru 02, 2009 9:01 am
Moderator
Moderator
Numer GG: 183187
No i chyba nie robili takich co by z jednej strony na błotniku przednim miały dziurki a na drugim nie.
Post: śr gru 02, 2009 9:28 am
Worek pisze:
No chyba robili [zlosnikz]
Post: śr gru 02, 2009 9:31 am
Worek pisze:
Jest OK, jest tylko jeden wlot powietrza do silnika.
fb.com/waxclusive
Post: śr gru 02, 2009 9:50 am
Moderator
Moderator
Numer GG: 183187
A to moja niewiedza wylazła jak szydło z worka :)
Post: śr gru 02, 2009 10:26 am
Złe spasowanie nie musi świadczyć o wypadkowej przeszłości.
Jak kupisz sobie nowy błotnik (stary skorodował), klepany gdzieś u Ziutka w piwnicy, to możesz mieć problemy z dopasowaniem. Dlatego warto kupić oryginalną używkę, która często jest 2x droższa.
Co do auta, to jakby był bez turbo i 4wd ... :roll:
w123 240D
s124 300D
Post: śr gru 02, 2009 1:47 pm
Ładny.. tylko ten 4matic. Generalnie nie jest to mistrzowskie rozwiązanie Mercedesa. Potrafi się sypać, a jak się sypnie, to kasy poleci sporo. Poza tym nie znasz dnia ani godziny.
W123 M115 ex
BMW e34 518 - sprzedam!
Renault Laguna 2.0 dCi 150 KM AT
Post: śr gru 02, 2009 2:54 pm
Kierowca bombowca pisze:
Mnie nie razi przód, wszystko wygląda na całkiem normalne [szalone]
Post: śr gru 02, 2009 4:35 pm
Widzę sporo opini na temat 4matica. Trochę czytałem na naszym forum o tym, że awaryjne, inne częsci, drogie, auto nie jest tak żwawe.
No dobra. Czy 4 matic ma w ogóle jakieś plusy? :lol:
Ogólnie szukam właśnie W124 TD( może TDT) w fajnym stanie i dobrym wyposażeniu. Jeśli znajdziecie coś na necie, podeślijcie mi linka, proszę.
Na szybko odnalazłem parę ładnie wyposażonych
1 http://allegro.pl/item823747914_mercede ... matik.html ahh, ten 4matic [zlosnik]
2
http://www.otomoto.pl/index.php?sect=show&id=C10672787
Pan wspomianł, że to farbowana Włoszka-pierwotnie brunetka;)
3
http://www.otomoto.pl/index.php?sect=show&id=C10780995
Ten ma piękne wyposażenie, ale ten przestawiony przód...
Czyżby to był taki parch, że nikt go nie łyknął od końca sierpnia? 3 miesiące? Fajny/niefajny :roll: ?
Mam jego VIN:
VIN WDB1241901F262259
Model 300 TD
Chassis 1241901F262259
Engine 603912 12 063187
Transmission 722415 03 348197
Order 0 3 226 70370
Approx. year not defined
Heating 0-22627373
Lights HELLA
Wiper BOSCH
Dealer Munich branch (226)
Paint
147 arctic white (T) (с 01.01.1985 по 31.12.1993)
Options
211 automatic limited slip differential (ASD) (с 01.07.1984)
installation kit for Becker AT 400 car phone, with 2 sets (с 01.09.1970 по 30.11.1974)
rear axle with automatic limited slip differential (ASD)
rear axle ratio 1:3,75 (m) (с 01.08.1963 по 31.12.1965)
second spare wheel (с 01.01.1964 по 28.02.1973)
281 trunk set, (280 SL)
trunk set, 3-piece (с 01.09.1972 по 30.11.1976)
trunk set, 4-piece (с 01.04.1963 по 31.01.1966)
steering wheel with sports design (390 mm dia.) and gearshift lever in leather trim (с 01.05.1990)
steering wheel (390 mm) with sports design (с 01.03.1989)
airbag for driver and front passenger (с 01.07.1987 по 30.09.1993)
garment trunk, large (с 01.02.1967 по 31.05.1973)
trunk set, 7-piece (с 01.01.1976 по 31.08.1978)
taxi design without compartment wall, taximeter instrument panel (с 01.01.1968 по 31.07.1968)
420 automatic transmission, floor shift (с 01.01.1963)
halogen lamp unit, crystal clear, r.h. traffic (с 01.08.1967 по 31.12.1972)
additional halogen lamps (с 01.01.1967 по 31.07.1967)
551 anti-theft warning system (с 01.11.1978 по 31.03.1998)
anti-theft/anti-break-in warning system with anti-towing system (с 01.04.1998)
steering wheel, ivory-colored (с 01.01.1963 по 31.05.1973)
587 front folding armrest
single seats with folding armrest (с 01.01.1963 по 30.09.1970)
automatic climate control and electric window lifters (front doors) (с 01.01.1977)
591 white foglamps (с 01.01.1963 по 31.07.1965)
heat-insulating glass, all-around, heated rear window pane, (single-sheet safety glass), Germany
heat-insulating glass, windshield shot-colored (с 01.02.1967 по 31.01.1971)
green heat-insulating glass all round, heated rear window, single pane safety glass - Germany (с 01.01.1972)
ECE version with catalyst technique (с 01.09.1983 по 28.02.1985)
version for Italy (с 01.01.1967 по 31.08.1969)
645 M+S tires (с 01.10.1963)
750 Becker radio Europa 2000 vk (с 01.06.1990 по 31.03.1994)
radio MB Audio 30 with traffic news decoder and RDS (с 31.10.1996)
855 V140 M119 with NAG (с 19.06.1996 по 19.10.1997)
telephone TELE-AID, Nokia, D-net
Post: śr gru 02, 2009 8:51 pm
wracając do tego co // nie ma takiego drugiego// nie wiem czy dobrze rozumię - Firma MB wypuściła tylko 1 egzemplarz :o toż to rarytas-ja bym brał bez namysłu :lol:
MB 124 300 24V CE-1991 EX
MB 126 560 SEL- 1988-LPG
AUDI A3 1.6-----1997-PB
DAEWO TICO----1997-LPG
MB 126 420 SE-- 1988 EX
IVECO 3510-----1995 EX
MB 124 300 E ---1989 EX
MB 201 230 E ---1987 EX
AUDI 80 1,8E----1989 EX
SEICENTO 900---2002 - LPG
Post: czw gru 03, 2009 1:24 pm
Xytras pisze:
Komentowałem jedynie post kolegi Fullsize, a sam się nie przyglądałem aż tak wnikliwie ;)
w123 240D
s124 300D
Post: czw gru 03, 2009 1:31 pm
A ja w sumie z lenistwa cytowałem Twoje bo było bliżej 8)
No ale poważnie, dla mnie to auto wygląda nieźle. Czasem warto się bliżej przyjrzeć bo już z autopsji wiem, że demontaż reflektora, ramki w jakimś tam celu powoduje, że potem trzeba troszkę się pomęczyć by wyglądało jak z fabryki :)
Post: sob gru 05, 2009 3:57 pm
skorpion986 pisze:
Mam jego VIN:
Model 300 TD
Order 0 3 226 70370
Heating 0-22627373
Lights HELLA
Wiper BOSCH
Paint
Options
Chłopaki, znacie to autko?
Post: pn gru 07, 2009 9:49 pm
Witam!
Kolego ten biały Mercedes to w mojej mieścinie stoi.
Jeżeli Ci zależy mogę podjechać go obejrzeć w piątek lub sobotę.
Udokumentuje oczywiście wyprawę fotograficznie.
Jak cos to PW.
C180 T-Model 98'
Mondeo mk4 2.0 PB 08'
C3 1.1 PB 12'
