Dzisiaj jest pn lis 16, 2026 9:43 pm
Post: pn kwie 20, 2009 2:48 am
Witajcie,
od wczoraj po 3 miesięcznym opóźnieniu, jestem szczęśliwym i prawowitym właścicielem tej oto damy [zlosnik] ---->
VIN WDB1230932F027453
Model 280 TE
Chassis 1230932F027453
Engine 110988 22 030212
Transmission 722309 02 525533
Order 0 4 402 00276
Approx. year 1984
Lights BOSCH BOSCH
Cab 00222
Dealer Tourists (without USA) (402)
Interior Unknown code (157)
Paint
881 thistle green metallic (? 01.01.1979 ?? 31.12.1986, ? 1994)
Options
286 luggage nets on front seat backrests (? 01.01.1962)
406 single seat with orthopaedic front seat backrest, left and right (? 01.07.1970)
411 mechanical and hydraulic sliding roof (? 01.10.1965 ?? 31.10.1993)
420 automatic transmission, floor shift (? 01.01.1963)
467 central locking system and instruments with english lettering (? 01.04.1970 ?? 31.10.1993)
470 anti-lock braking system (abs) (? 01.06.1978 ?? 31.10.1993)
518 Becker radio Avus cassette stereo Kurier MW/USW (? 01.11.1982 ?? 31.07.1986)
531 automatic antenna (? 01.01.1963)
541 double roller blind used as luggage and passenger guard (? 01.01.1980)
550 trailer coupling (? 01.03.1965)
570 folding armrest front w202/210 stowage box front with armrest (? 01.04.1970)
front folding armrest w202 - housing at front with armrest
586 Behr air conditioner, and electric window lifters (front and rear doors) (? 01.04.1970)
593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (? 01.01.1972)
605 headlamp wiper unit and license plate mounting (? 01.08.1971)
oil for rear axle with limited-slip differential in canisters and trim strips on hardtop
613 lamp unit, asymmetrical, l.h. traffic (? 01.02.1963)
812 rear-mounted loudspeaker (? 01.11.1974)
843 rear seat bench divided 2/3 : 1/3 (? 01.10.1977 ?? 31.08.1996)
844 folding seat bench in loading compartment, reverse to direction of travel (? 01.10.1977)
873 Unknown code--Grzane fotele przednie
Jak to bywa w angolskich pojazdach , wszytko się zgadza z VINem. Jestem drugim właścicielem od nowości, poprzedniczką była kobitka zamieszkująca Bristol...Oddała go (lub ktoś z jej rodziny??--oby nie
:-? ) na pewien dobrze mi znany auto shrot , mam nadzieję że poprzedniczka jeszcze żyje bo zależy mi na wydębieniu od niej jakichkolwiek dokumentów, papierów i świstków podrasowujących historię tego Mercedesa...jedynie co udało mi się załatwić z urzędu (tzw. DVLA) kopie paru kwitów jak akt pierwszej rejestracji i coś tam o wydaniu pojazdu z salonu MB? Zależało by mi na książce serwisowej i fakturze zakupu MB, w niedalekiej przeszłości podjadę do exownerki zagadam i wyczaję co się da załatwić [zlosnik]
Tyle o rodowodzie ale do rzeczy...uratowałem kolejnego MB przed rychłym zgniotem hydrauliczne prasy i szczerze cieszę się z tego ;) Stan pojazdu nie jest tak dobry jak było to w przypadku Ogóra ale nie jest aż tak agonalny jak w przypadku Srebrnej 8) ...jest to stan pośredni między w/wymienionymi. Samochód wymaga prac blacharskich jak i wglądu w silnik choć pracuje on o dziwo cicho i równo paląc od 1 obrotu rozruchem. Z rzeczy które trzeba naprawić to centralny (banał na max 1h roboty), klima choć to było oczywiste, oraz wycieraczki przednich lamp. Reszta elektryki działa bez zarzutu wliczając BECKERA i el antenę oraz grzanie przednich foteli ;) Pierwszy raz miałem przyjemność przetestować zabawę FADEREM i cieszyć się ładnym ,czystym brzmieniem radia płynącym z oryginalnych 4 głośników [zlosnik] Skrzynia nie szarpie i gładko wrzuca biegi nawet z D<-->N<-->R. Muszę jeszcze przetestować NIVO ale wydaje się być sprawne, rama szybra raczej przecieka ale tylko z lewego odpływu :-? , Prawa strona podłogi jest w rzeczywiście lepszym stanie...dywaniki suche oprócz przedniego lewego nieco mokrawego od spodu :cry: Tapicerka w ślicznym stanie brak rozdarć czy innych pęknięć ale osłona lewego słupka środkowego ma 2 ubytki/dziury, podsufitka przepiękna z małym "buuu" na lewej krawędzi ramy szybra. Generalnie auto jeździ i działa...już niedługo przyjedzie do Polski na leczenie a kto wie może nastąpi delikatna transformacja i wstąpi w niego jakiś 500-560 V8???? [zlosnik] [zlosnik] (o tym już niebawem [oczko] )
Ale my tu gadu gadu a foty czekają...zapraszam do galerii....trochę ogarnąłem go w środku i na zewnątrz bo kibel był i jakieś włosy z psa czy innego zwierza :P a jak wiemy nie przystoi mieć syf w Mercedesie...
Lewarek z prawdomówną podstawką :-)))))))))
Oraz jej lepsza strona --- to tak dla tych co szukają małej Daten Karty w swoich kombiałkach..
[zlosnik] [zlosnik] [zlosnik]
MB S124 280TE 96r.-BeetrooT
Post: pn kwie 20, 2009 6:56 am
Poza nadkolem auto w niezlym stanie skory dobrze wygladaja
Post: pn kwie 20, 2009 7:37 am
Piekne wnetrze, wg. mnie najladniejszy kolor, nawet od granatowego.
Konfiguracja moich marzen to lakier ciemna zielen i to wnetrze.
Niezly wypas, ale chyba sporo pracy przed Tobą?
W123 280CE
Porsche Cayenne Diesel S
Mercedes CLA
Post: pn kwie 20, 2009 7:52 am
Wszystko super ale kierownik nie z tej strony :o
SAAB 99 2.0 16v 1983r
W124T E250 Diesel 1995r
Post: pn kwie 20, 2009 9:48 am
b@rtek bardzo bym chciał żeby to były skóry [zlosnik] ale zadbany MB-tex też daje radę ;)
300D pisze:
Moja ulubiona konfiguracją natomiast jest konfiguracja którą posiada OGÓR (876+dattel w skórze)[cool] ;) że tak nieskromnie powiem...
Pracy będzie dużo...ale jestem na to gotowy i mam już pewne doświadczenie z kompleksową odbudową [zlosnik]
RAFAŁ 99 nic nie dyziaj...ja tu jestem skazany na ten ustrój i te wymogi więc nie płaczę...no i w każdej chwili mozna taki pojazd w PL zarejestrować bez przekładki...w razie czego...jakby miało się w PL poprawić [zlosnik] :lol:
Post: pn kwie 20, 2009 9:54 am
Ha! Twój też na deklach ze 124 :)
Lece zobaczyć czy mam te denko przy podstawie podnośnika - dzięki za to zdjęcie, możesz sobie przyznać punkt pomoc [zlosnik]
Wspaniały wypas i dziwaczna (chociaż ładna) kombinacja kolorów wnętrza/lakieru.
Post: pn kwie 20, 2009 4:42 pm
swietny! porzadny wypas i wnetrze mimo ze to MB-Tex powala [ok] [slinka]
troche dlubania przy nim jest ale i tak fajny [oczko]
S123 230TE '81+pare innych
Post: pn kwie 20, 2009 5:20 pm
ZORTOX pisze:
bardzo bym chciał żeby to były skóry ale zadbany MB-tex też daje radę
Moj blad... [zlosnik] ale mimo wszystko w srodku kozak :evil:
Post: pn kwie 20, 2009 11:50 pm
jutro w południe ładuję furę na TIRa i wysyłam do Polski...do Ogórkowej siostry :lol: Długo się nie nacieszyłem ale test drive zaliczony [cool] , zbiera się dość żwawo i reaguje w odpowiednim czasie na zamysły kierowcy ;)
Będzie to transport tzw. "2 w 1" bo zapakuję go wszystkimi skarbami gromadzonymi na strychu...a jest tego od zarypania...mam nadzieję że wszystko wejdzie [cool]
Post: wt kwie 21, 2009 10:09 am
ZORTOX pisze:
mam nadzieje ze moje gratki tez tam beda?! :P
Post: wt kwie 21, 2009 1:54 pm
Wnetrze mimo, że z MB tex'u jest świetne, gratuluje auta. Nabardziej zazdroszcze Ci elektryki, no i tej ławeczki :lol:
ZORTOX pisze:
Czyli będzie 500TE, lub 560TE? [zlosnik]
S123 300TD
Post: wt kwie 21, 2009 5:46 pm
kierownica po złej stronie i do tego jeszcze odwrotnie zamocowana :-):-):-) a datenkarta wygląda, jakbyś ją właśnie wydrukował :-):-):-)
to chyba z zazdrości,sorry:-)
piękne auto, piękne wnętrze i całkiem niezły wypasik.
gratuluję pięknego auta.
piękny :-)
'66 Wartburg 312/1
'69 w114 250CE
'69 w108 280SEL
'77 w116 450SEL 6.9
i inne Pontony
Post: śr kwie 22, 2009 2:23 am
aegm pisze:
ależ będą będą ;) no problemos 8)
MajsterGarage pisze:
Dzięki [zlosnik] :lol: [smiech] ...no elektryka jeżeli o tym mówisz:
tu jest w maksymalnej opcji o ile się nie mylę...(dało się coś jeszcze zamówić więcej co działa tylko na prąd?? :roll: )aaaaa przyszło mi do głowy że mógłby być jeszcze 2 tonowy klakson..ale w wersji kombi nigdy nie widziałem :roll:
Jest duża szansa...się naoglądałem tego 560TE na YouTubie i się zakochałem [zlosnik] , dawcę trzeba będzie kupić w całości a o to tutaj nie trudno ;) . Poczekamy najpierw jak się buda naprawi...i co mistrz Tomek wyrazi na ten temat. Silnik oryginalny 2.8 się zostawi w razie chęci powrotu do oryginału [oczko]
szykido całokształtu zapomniałeś dodać że niema lewego narożnika w drewku [oczko] bo rzeczywiście niema :cry: i trzeba będzie zastosować wymianę całego poziomego drewka z innego kompletu...ale z to raczej nie problem.
No to jeszcze przedstawię moment załadunku i pożegnania z Teówką ;) ...
się gościu oczywiście spóźnił...tylko godzinkę bo...yyy zupa była za słona :evil: ale wybaczyłem mu bo skruchę okazywał :roll:
Dociążenie gratami było dośc spore [smiech]
Siadło mu dupsko...już mi się nie chciało pełzać i miąchać wajchą regulatora NIVO od spodu...ale najważniejsze że tłumokiem o dziwo NOWYM !!! nie ciągnął po glebie
No i już na przyczepie...wjeżdżając po podjazdach przywaliłem czymś o krawędź przyczepy...na szczęście były to tylko przydługawe śruby obejmy środkowego tłumika...się "wygły" nieco :-(
To by było na tyle z obcowania z pojazdem...zobaczymy się u Stomka w maju...poczułem i doceniłem jak komfortowym, uniwersalnym i ponadczasowym samochodem jest ten model Mercedesa...szczególnie jak znów wsiadłem w to szare coś zwane przeze mnie "Szarakiem" czyli 205 1.8D [zlosnik] [zlosnik] [zlosnik]
