Dzisiaj jest śr paź 28, 2026 1:27 am
Post: wt lip 22, 2008 2:06 pm
Witam, chcialem sie tylko przywitac. :)
Stalem sie szczesliwym posiadaczem MB W124 CE300 24V Sportline
Zdjecia zamieszcze jak tylko porobie :)
Narazie tylko opis :)
Model 300 CE-24
Lights HELLA
Wiper BOSCH
Paint
199 metallic blue-black (с 01.01.1983)
Options
211 automatic limited slip differential (ASD) (с 01.07.1984)
rear axle with automatic limited slip differential (ASD)
240 outside temperature indicator (с 01.03.1982)
260 elimination of model designation on rear lid (с 01.05.1968)
281 trunk set, (280 SL)
steering wheel with sports design (390 mm dia.) and gearshift lever in leather trim (с 01.05.1990)
steering wheel (390 mm) with sports design (с 01.03.1989)
425 5-speed automatic transmission (с 01.02.1988)
430 headrests in the rear (с 01.01.1977)
442 airbag in steering wheel (с 01.02.1980 по 31.10.1993)
538 automatic antenna and front loudspeaker - without radio set (model 500SEC with loudspeaker only) (с 01.10.1989)
581 automatic climate control (с 01.01.1977)
620 emission control system
vehicles with catalyst technique (с 01.03.1985)
653 sports chassis with 8-hole light alloy rims (с 01.01.1990)
812 rear-mounted loudspeaker (с 01.11.1974)
873 seat heater for left and right front seats (с 01.02.1984)
952 rotating emergency flasher, front (red light)
sportline with 8-hole rim(consisting of codes 65/3, 243, 281) (c 124: codes 65/3, 281, fabric, check a3) (a 124: codes 65/3, 281)
