Dzisiaj jest pn paź 26, 2026 2:31 pm
Post: ndz sty 20, 2008 9:04 am
Witam. Dziś zamieniłem swojego 126 260e na 126 300D (ex 380e).
Podaję Vin
VIN WDB1260321A125559
Model 380 SE
Chassis 1260321A125559
Engine 116963 12 061430
Transmission 722310 02 585004
Order 0 4 571 31261
Approx. year 1984
Lights BOSCH
Cab 11606
Dealer Switzerland (571)
Interior cloth mushroom (075)
Paint
172 anthracite grey metallic (с 01.01.1963)
Options
240 outside temperature indicator (с 01.03.1982)
256 rear axle with limited-slip differential (с 01.11.1965 по 30.11.1991)
257 Becker radio Europa Kurier LW/MW/SW/USW (с 01.08.1975 по 30.11.1990)
260 elimination of model designation on rear lid (с 01.05.1968)
410 electric sliding roof (с 01.03.1965 по 29.02.1988)
430 headrests in the rear (с 01.01.1977)
440 tempomat (cruise control) (с 01.09.1975)
470 anti-lock braking system (abs) (с 01.06.1978 по 31.10.1993)
504 outside rear view mirror, right, electrically adjustable (с 01.11.1978 по 29.02.1986)
outside rear view mirror, right, electrically adjustable (l.h.d.)
taxi version, f.r.g, and outside rear view mirror on the right
531 automatic antenna (с 01.01.1963)
570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
586 Behr air conditioner, and electric window lifters (front and rear doors) (с 01.04.1970)
592 heat-insulating glass, all-around, heated rear window pane (laminated glass), band filter
green heat-insulating glass all round, heated rear window, laminated safety glass - tinted strip (с 01.01.1972)
603 headlamp wiper unit and oil for rear axle with limited-slip differential, in canisters and containers (с 01.08.1971)
628 version for Switzerland (с 01.02.1982 по 31.10.1989)
630 ECE warning triangle (с 01.08.1980)
673 high-capacity battery (с 01.01.1964)
805 Change of year of model, last figure shows new model year
Nie rozumiem za bardzo o co doladnie chodzi w pozycjach : 256, 504 taxi??, 586, 592, 603, i czym się różni wersja na Szwajcarię??
Z góry dziękuję za pomoc i pozdrawiam [zlosnikz]
W202 C220D(wersja Elegance) '94r- mamuśki
BMW E34 525i Touring (wersja Shadow Line) '93r-sprzedałem...
VW Passat '91r kombi 1.9D- rozbiłem...
W126 260 SE '87r - sprzedany...
W126 ex380> 300D '85r - sprzedany...
VW Passat '91r kombi 1.8i
Post: ndz sty 20, 2008 10:55 am
Gratuluję diesla i bezstresowej jazdy.
Kod 256 - tylny most ze szperą (Sperrdifferenzial).
Kod 504 - prawe lusterko elektrycznie regulowane.
Kod 586 - klima i elektryczne szyby przód i tył.
Kod 592 - wszystkie szyby termoizolacyjne plus grzana tylna szyba.
Kod 603 - wycieraczki przednich świateł.
Kod 628 - pewnie jakaś ekologia.
To tak mniej więcej. Resztę Ci inni dopiszą.
Post: ndz sty 20, 2008 11:19 am
Jaki dokładnie silnik jest w tym 126 ?
Post: ndz sty 20, 2008 12:01 pm
zapewne 300 D (albo ze 123 albo 124 - tego kolega nie napisał). Wcześniej był 3,8. Czy po takiej przekładce jazda będzie bezstresowa ? cięzko oceniać - ja tego życzę z całego serca
ex. W124 E220 ASB, BRC Seq 24
ex. Corolla E11 1.4
ex. Toledo I 1.8, BRC II Gen
Post: ndz sty 20, 2008 1:17 pm
Czy masz sprawną klimę? Też interesuję się jakimś skundlonym W126, ale zazwyczaj klima po przekładce silnika nie jest już kompletowana...
Jeep Grand Cherokee 5.2 '96
Post: ndz sty 20, 2008 1:54 pm
Może pokażesz nam fotki ?
Plastikowa Corsa.
Post: ndz sty 20, 2008 2:58 pm
Ok dzięki. Klima rzeczywiści chyba raczej nie działa. Silnik jest 300D od W123 do tego 4 biegowa manualna skrzynia biegów. Fotki zrobię jak trochę go umyję bo jest strasznie zasyfiony. Powiem tyle że ma jasne skórzane obicia na drzwiach i na boczkach a poprzedni właściciel zmienił mu tapicerki na bardzo łądną ciemną :)) Przydałoby się mu troszkę poprawić blacharkę z tyłu a poza tym jest oki. Silnik zapala na dotyk i jak na razie jest dobrze ( w nocy zrobiłem nim 200 km). Foty będą niedługo.
Pozdrawiam i dzięki za pomoc :)))
Post: ndz sty 20, 2008 3:28 pm
Szkoda że tylko OM617 [cool]
