Dzisiaj jest śr paź 28, 2026 5:24 pm
Post: wt lut 20, 2007 7:56 pm
Ile mogą być warte części z listy poniżej. Niestety mam ją tylko w języku angielskim i za mało czasu by wszystko przetłumaczyć. Z góry dziękuje za pomoc.
1x000 071 2128 Bi metallic spring for auto choke new `
1x000 091 0840 Fuel Filter Bowl new `
1x000 543 8315 Switch new `
1x001 586 7343 116 rear calliper repair kit new `
1x001 820 1307 Rep Kit new `
1x001 997 2752 Hydraulic Hose new `
1x002 997 7337/427 111 7070 Pump new `
1x002 431 0602 Master cylinder reservoir new `
1x002 545 0114 Cut off switch `
2x003 997 7436 valve new `
1x016 545 5532 ecu `
3x102 078 2881 hose new `
1x102 200 0677 fan magnet new `
1x102 203 0473 housing new `
1x103 030 0512 auto flywheel new `
1x107 464 0112 steering wheel horn connecter new `
2x107 490 0041 repair kit new `
1x107 586 0132 anti roll bar repair kit new `
2x107 720 1578 ¼ seal new `
1x107 725 0566 seal new `
1x107 830 0385 heater control lever new `
10x107 988 0778 clip new `
1x111 142 0380 exhaust manifold gasket new `
4x111 776 8097 Washer new `
3x115 016 0081 hose new `
1x115 180 0102 oil pump new `
3x115 260 0353 Knuckle joint `
1x115 260 0648 repair kit new `
1x115 760 0261 1nterior door handle new `
1x116 150 3018 H/T lead `
2x116 320 0437 rear anti roll bar link new `
1x116 353 2652 washer new `
1x116 586 0073 Rep kit new `
1x116 586 0888 Rep kit `
1x116 680 ???? zebrano heater panel new `
1x116 680 0071 Int Chrome `
2x116 Eye brow chrome, above headlamp L & R `
1x116 730 ???? o/s/r door 116 se +glass, winder mech, door handle, chrome `
1x116 ??? ???? N/S/R SEL door trim `
2x116 758 0058 boot star one new `
2x116 760 0059 Rear door handles `
1x116 760 0159 Front door handle, no key `
2x116 760 0259 Front outer door handles, no keys `
3x116 766 0211 O/S/R Int handle backing `
1x116 817 1515 450 SEL boot badge `
1x116 Left rear window switch `
1x116 821 0051 heater switch `
1x119 070 0246 injector new `
1x123 328 0531 hydraulic suspension valve `
1x123 420 5028 brake pipe new `
1x123 Chrome hub cap new unpainted `
1x123 620 0185 radiator support bar new `
1x123 Zebrano heater panel `
2x123 723 0124 Int door catch chrome `
1x123 723 0224 Int door catch chrome `
1x123 750 0885 Boot lock, no key `
1x123 760 0161 Int door handle `
1x123 760 0261 Int door handle `
1x123 800 1219 central locking reservoir new `
1x123 Interior mirror `
1x123 811 0441 o/s mirror manual `
1x123 817 0615 250 Boot badge `
1x123 817 1515 240TD Tailgate badge `
1x123 817 2015 230E Boot badge `
1x123 Ash tray black `
1x123 820 0505 hazard warning switch `
2x123 820 ???? Sun roof motors `
1x123 820 5064 o/s/r lamp `
1x123 880 0670/1270 front bumper with rubbers `
1x123 918 2930/8211 seat side cover new `
1x124 276 4096 line new `
1x124 300 2125 throttle rod new `
1x124 Differential `
1x124 505 1688 radiator cover new `
1x124 540 0017 sensor cable new `
1x124 628 5298 seal new `
1x124 670 0939 seal new `
1x124 690 0162 moulding new `
1x124 805 0590 cover new `
1x124 820 3077 o/s/rear lamp backing new `
1x124 820 0110 Hazard warning switch `
1x124 880 0197 seal new `
1x124 910 0285 seat gearing new `
1x124 919 0220/3112 cover new `
1x126 401 0824 Hub cap `
1x126 720 0148 n/s/f door rubber `
1x126 720 0248 o/s/f door rubber `
1x126 Front door handle, no key `
1x126 727 0530 Seal new `
1x126 736 0317 Int door handle `
1x126 780 1689 Sun roof cable new `
1x126 869 0608 washer bottle lid new `
1x126 880 1397 fixing kit new `
1x126 885 2523 bumper joint chrome new `
1x129 720 0111/5070 cover new `
1x129 770 1998 seal new `
1x129 820 0477 o/s/rear lamp backing new `
1x129 860 0335 hood ram `
1x140 277 2814 plate new `
1x140 460 1041 steering wheel air bag bracket new `
1x140 760 0370 exterior door handle new `
1x140 976 0325 Seat motor new `
1x140 970 0625 seat motor new `
2x201 330 0051 front wheel bearing kit new `
1x201 540 0331 Earth cable new `
1x201 689 0087 hook new `
1x201 689 0880 lamp switch cover new `
1x201 725 0365 Seal new `
1x201 820 1742 n/s head lamp washer motor new `
1x201 831 0142 Heater vent new `
1x201 Hood damper `
1x202 265 0174 pin new `
1x202 290 0319 housing new `
1x202 292 0031 lever new `
1x202 320 0056 repair kit new `
1x202 drive shaft `
1x202 Front wheel bearing kit new `
1x202 Rear screen blind, no fittings `
1x202 720 0115 window guide new `
1x202 N/S/R Window motor `
1x202 door lock handles & ign and steering lock & key `
2x202 820 0245 head lamp wiper blade new `
1x202 830 0854 vent new `
1x208 690 0262 o/s moulding `
1x210 820 0144 wiper arm new `
2x460 723 0052 Door hinge pin `
1x673 540 0545 Indicator switch `
2x901 720 0435 Seal `
1x973 820 1261 O/S Head lamp `
1x Sony rm-x2s control unit for CD player `
1x Pitch pine storage case with Auto Union logo `
1985 W123 230E "Perełka" Babcia Emerytka
1983 W123 300D "Umklajder"
Płyń stary płyń niech wiatry Ci sprzyjają...
Post: wt lut 20, 2007 8:04 pm
[zlosnik]
W114 280C 1974 "Esther"
Post: wt lut 20, 2007 9:07 pm
000 091 0840 2.20
000 543 8315 39,84
001 586 7343 16.94
001 820 1307 27.58
001 997 2752 25
002 431 0602 29.52
003 997 7436 74.77
016 545 5532 1139.92 :O
102 200 0677 172.59
102 203 0473 24.49
103 030 0512 154.35
107 720 1578 76.85
107 725 0566 19.45
107 830 0385 213,45
107 988 0778 0.56
111 776 8097 4.22
115 016 0081 4.46
115 260 0353 6.63
115 260 0648 11.16
116 150 3018 43.52
116 320 0437 34.64
116 680 ???? od 200 do 600
116 758 0058 17.66
116 760 0059 97.31
116 760 0159 108.18
116 760 0259 108.18
116 766 0211 28.31
116 817 1515 20,92
116 821 0051 92,40
119 070 0246 173.00
123 420 5028 3.36
123 620 0185 14.09
123 723 0124 8.64
123 723 0224 8.64
123 760 0161 14.48
123 760 0261 14.48
123 800 1219 5.11
123 811 0441 50.95
123 817 0615 11.15
123 817 1515 18.03
123 817 2015 12.87
123 820 5064 174.54
124 300 2125 18.11
124 505 1688 4.28
124 540 0017 169.52
124 690 0162 22.70
124 805 0590 2.21
124 820 0110 10.69
124 910 0285 74.23
124 919 0220 2.40
126 780 1689 33.56
126 869 0608 1.27
126 880 1397 103.75
126 885 2523 15.06
129 720 0111 25.39
129 770 1998 41.28
129 820 0477 66.03
129 860 0335 550.24
140 277 2814 17.79
140 460 1041 8.39
140 760 0370 41.94
140 970 0625 150.98
201 330 0051 46.56
201 540 0331 7.59
201 689 0087 1.19
201 689 0880 2.08
201 725 0365 9.20
202 265 0174 3.76
202 292 0031 1.63
202 830 0854 29.52
208 690 0262 44.08
210 820 0144 43.01
460 723 0052 2.30
673 540 0545 184.67
973 820 1261 142.28
ceny w euro (za sztukę) za nowe części z katalogu DaimlerChrysler AG
Post: wt lut 20, 2007 9:09 pm
piston w ktorym ASO pracujesz?
Toyota MR2 2,0 '93
Ex: W124 300E 4matic '87
Post: wt lut 20, 2007 9:11 pm
w żadnym :p
w124 400E 93'
s210 320CDI 00'
w201 3.0 24v 89'
Post: wt lut 20, 2007 9:13 pm
szkoda, juz liczylem na wiekszy rabacik
Toyota MR2 2,0 '93
Post: wt lut 20, 2007 10:03 pm
Wielkie dzięki za pomoc. Być może niedługo stanę się szczęśliwym posiadaczem tego wszystkiego.
