Dzisiaj jest pt lis 21, 2025 8:33 am
Post: pt mar 25, 2005 1:21 pm
:))) ok now is much better:)) but we still don't know what kind of car do You have. Write please something more about that - then we can give You correct answer :)))
Post: pt mar 25, 2005 9:19 pm
i dont understand what angels do you mean.
if you think about weels geometry here it is:
In W115 rear weels are constant ,you can not change their position .
front weels depend on mark (I or II).
I -before 1973;II after 1973
write somethink about the car and we try to give you corect advice
best regards
maciej
240D3.0, no...i wszystko jasne
Post: ndz mar 27, 2005 8:41 pm
Hi
Try to do it along below informations:
front axle
convergence 2...4 [mm] lub 0o15'... 0o35'
wheel inclination 0o15'+10'-20'
king-pin angle lead 2o20'... 3o
king-pin inclination 6o
rear axle
convergence 0...3 [mm]
wheel inclination -0o45' [mm]
little "o" means degree
I took this details from: http://macmerc.netium.com.pl/index0.html
Good luck
