Dzisiaj jest sob gru 13, 2025 11:06 pm
Post: czw maja 31, 2018 2:12 pm
Numer GG: 9309000
Cześć.
Muszę się rozstać z moją Loszką. Może ktoś tutaj znajdzie się chętny.
VIN WDB1400701A314589
Baumuster 140070
Sales name S 500
Order number 0 5 226 64478
Delivery date 1996-03-18
PAINT1 366U
Interior color 265A
Engine 119980 12 006857
Front axle 2 BE1650T1050220542512
Gearbox 722620 00 021530
Lights units BOSCH
Class 1
Code Value
260 TYPE DESTINATION ON TRUNK LID - ELIMINATION
265A No code designation available
366U AZURITE BLUE - METALLIC
472 ELECTRONIC STABILITY PROGRAM (ESP)
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
561 REINFORCED DRIVER SEAT, LEFT
806 AEJ 06/1/M/X
980 REG. DOC. AND ABE NO. ON TYPE LABEL FOR EXPORT
SA numbers
Group Codes
42 42 11581/01/
54 54 11304/34/
62 62 56795/41/
72 72 56795/41/
75 75 56795/41/
80 80 56407/22/ 80 56407/31/ 80 56795/41/
82 82 56407/22/ 82 56407/31/ 82 56896/02/ 82 56896/03/
88 88 56795/41/
Coupe of the series 140
Mercedes-Benz type CL 500
Type CL 500
Name CL 500
Name Mercedes-Benz type CL 500
Short name CL 500
Model C 140 E 50
Production since 06.96
Number produced in production
Comments concerning the production period
Prices 06.96: 173.822,50 DM 03.97: 173.880,00 DM
Wheelbase 2945 mm
Track rear/front 1614/1587 mm
Length 5065 mm
Width 1912 mm
Height 1452 mm
Smallest turning circle 11,66 m
Chassis weight
Max. total weight 2600 kg
Max. front axle weight 1240 kg
Max. rear axle weight 1360 kg
Max. load 520 kg
Max. trailer weight braked 2100 kg
Max. trailer weight unbraked 750 kg
Weight empty 2080 kg
According to guideline DIN 70020 (with fuel, spare wheel and tool equipment)
Operating method four-stroke Otto (w/ manifold-injection and emission control device w/ three-way catalyst)
Configuration front, parallel; upright
Type M 119 E 50 / 119.970
No. of cylinder/configuration 8 / 90?-V-form; light-alloy block
Bore x stroke 96,5 x 85,0 mm
Total displacement 4973 ccm
Compression ratio 11,0
Crankshaft bearing 5
Output 235 kW / 320 hp at 5600 /min
Maximum torque 470 Nm at 3900 /min
No. of valves/configuration 2 intake, 2 exhaust / V-shaped overhead
Valve operation 2 top camshafts per cylinder line (intake camshafts adjustable)
Camshaft drive duplex roller-type chain
Mixture formation microprocessor-controlled injection system w/ hot-film air-mass sensor (engine control Bosch ME)
Cooling water cooling / pump; 16,5 l water
Lubrication pressure circulation lubrication / 8,0 l oil
Electric system 12 V
Battery 100 Ah / in the boot
Dynamo three-phase AC / 1680 W
Starter motor electrical / 1,8 kW
Ignition ignition mapping control
Fuel tank above the rear axle / 100 l
Fuel supply electric supply pump
Driven whells rear wheels
Power transmission divided cardan shaft
Frame desing self-supporting all-steel body
Wheel suspension front double wishbone
Wheel suspension rear multilink suspension, on demand with hydropneumatic level control
Suspension front coil springs, torsion bar stabilizer
Suspension rear coil springs, torsion bar stabilizer
Damper gas-pressure damper
Steering ball-and-nut power steering
Steering transm ratio 14,02:1 / 2,96 steering wheel turns
Breaking system braking system
Breaking system hydraulic dual-circuit braking system with vacuum-operated brake ~servo unit and antilock device, since 12.96 with brake assistance device;~internally ventilated disc brakes front and rear
Parking breake parking brake
Parking breake mechanical (foot-operated), effective on rear wheels
Diamatre brake discs front / rear: 320 / 300 mm
Wheels light-alloy disc wheels
Wheels rims 8 1/2 J x 18 H 2
Tyres 255/45 ZR 18
Gearbox 5-speed autom. gear shift with electron. control
Availability Series
Shifting Switch lever in car center
Clutch hydr. torque converter with slip control clutch
Type of gearbox Planet gear
Synchromesh gears
Gear transmission I. 3,59; II. 2,19; III. 1,41; IV. 1,0; V. 0,83; R. 3,16
Differential ratio 2,65
Maximum speed 250 km/h (controlled)
Accelerations 7,5 s
Comments Acceleration with shifting through from 0 - 100 km/h; loaded with 2 persons
Fuel consumption 8,7/10,3/17,6 l
acc. to guideline 80/1268/EWG; values for 90 km/h / 120 km/h / city cycle
Krótka historia auta
Samochód sprowadzony przeze mnie z Niemiec w 2014 roku,
Zrobiłem wtedy serwis (Wolnik Katowice), w którego skład wchodziło:
1. wymiana oleju w silniku
2. wymiana oleju w skrzyni
3. wymiana sprężyn (wszystkie 4)
4. wymiana przednich żarówek na OSRAM Nightbreaker
5. zmiana felg na Kesskin 18"
6. zakup nowych opon
7. skorygowałem licznik do zera.
w 2016 w ASO Mercedes w Zabrzu zrobiłem:
1. hamulce przednie
2. serwis olejowy
3. filtr powietrza
4. Płyn hamulcowy
W sumie przejechałem nim 14000 km (tyle wskazuje licznik). Auto więcej stoi niż jeździ.
Ma też kilka drobnych usterek.min:rysy na zderzaku, bąbel rudego na lewym nadkolu, w środku brak trójkącika przy lusterku itp.
Wyposażony min:
- skórzana tapicerka, beżowa
- 4 x elektryczne szyby
- elektryczne lusterka
- elektrycznie regulowana kolumna kierownicy
- elektrycznie regulowane fotele z pamięcią
- radio CD
- szyberdach
- 18 calowe alufelgi
- pneumatycznie regulowane zagłówki
- pięciostopniowa skrzynia biegów (spalanie na poziomie 12-20L)
- ABS,
- aSR (kontrola trakcji),
- asystent parkowania,
- centralny zamek,
- immobilizer,
- poduszka powietrzna kierowcy,
- poduszka powietrzna pasażera,
- klimatyzacja automatyczna,
- klimatyzacja dwustrefowa,
- podgrzewane fotele
- przyciemniane szyby,
- wspomaganie kierownicy
Auto obecnie przebywa w Bielsku-Białej w firmie Scratch Killers, profesjonalnie zajmującej się polerowaniem, detailingiem, czyszczeniem jak i renowacją skór gdzie przechodzi gruntowną polerkę całego nadwozia jak i odświeżenia skór.
Cena jaka mnie interesuje to 32tys. Rozważę każdą propozycję, jestem w potrzebie :)
tel.609-555-695
IMG_4664.JPG [ 201.4 KiB | Przejrzano 3597 razy ]
IMG_4668.JPG [ 228.13 KiB | Przejrzano 3597 razy ]
IMG_4666.JPG [ 221.96 KiB | Przejrzano 3597 razy ]
IMG_4667.JPG [ 231.41 KiB | Przejrzano 3597 razy ]
IMG_4673.JPG [ 220.12 KiB | Przejrzano 3597 razy ]
IMG_4670.JPG [ 243.9 KiB | Przejrzano 3597 razy ]
IMG_4669.JPG [ 212.68 KiB | Przejrzano 3597 razy ]
IMG_4671.JPG [ 234.82 KiB | Przejrzano 3597 razy ]
IMG_4672.JPG [ 216.37 KiB | Przejrzano 3597 razy ]
IMG_3333.JPG [ 265.65 KiB | Przejrzano 3597 razy ]
C140 CL500 - '96
Post: czw maja 31, 2018 2:20 pm
Numer GG: 9309000
dodatkowe foty
IMG_3338.jpg [ 46.85 KiB | Przejrzano 3596 razy ]
IMG_4676.JPG [ 142.72 KiB | Przejrzano 3596 razy ]
IMG_4677.JPG [ 173.11 KiB | Przejrzano 3596 razy ]
IMG_4675.JPG [ 200.62 KiB | Przejrzano 3596 razy ]
IMG_4674.JPG [ 157.59 KiB | Przejrzano 3596 razy ]
IMG_3337.JPG [ 124.67 KiB | Przejrzano 3596 razy ]
IMG_4665.JPG [ 242.22 KiB | Przejrzano 3596 razy ]
IMG_3335.JPG [ 170.38 KiB | Przejrzano 3596 razy ]
IMG_3336.JPG [ 184.93 KiB | Przejrzano 3596 razy ]
C140 CL500 - '96
