Dzisiaj jest pn gru 01, 2025 1:38 pm
Post: pt lut 19, 2010 9:11 pm
Niestety, ruskie strony z przyklejonego tematu mi nie pomogły, wyskoczyło, że VIN jest albo żle wpisany, albo samochód jest lewy itd.
Mógłbym prosic o pomoc?
VIN WDB1241311C134471
Post: pt lut 19, 2010 9:17 pm
Model E 300 DIESEL
Chassis 1241311C134471
Engine 606910 12 008939
Transmission 722435 03 520875
Order 0 4 531 12498
Approx. year 1994
Lights HELLA
Wiper SWF
Cab 00000
Dealer France, Monaco (531)
Interior fabric gray+slate gray+orion gray (008)
Paint
199 metallic blue-black (с 01.01.1983)
Options
240 outside temperature indicator (с 01.03.1982)
291 airbag for front passenger
airbag for front passenger (с 01.10.1993)
airbag for driver and front passenger (if driver airbag standard - then only for passenger)
300 storage box in front tray (с 01.05.1988)
420 automatic transmission, floor shift (с 01.01.1963)
430 headrests in the rear (с 01.01.1977)
524 paintcoat preservation (с 01.01.1964)
538 automatic antenna and front loudspeaker - without radio set (model 500SEC with loudspeaker only) (с 01.10.1989)
543 sun visor with vanity mirror, illuminated, left and right (с 01.11.1978)
570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
585 Behr air conditioner and electric window lifters (front doors) (с 01.04.1970)
593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972)
611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.1978)
620 emission control system
vehicles with catalyst technique (с 01.03.1985)
630 ECE warning triangle (с 01.08.1980)
731 wood trim, burred walnut root (с 01.08.1980)
826
915 fuel tank, 70 liter (с 01.05.1988)
Post: pt lut 19, 2010 9:19 pm
dziekuje bardzo!
Post: pt lut 19, 2010 10:05 pm
Witam serdecznie.
Bardzo zależy mi na rozszyfrowanie nr VIN mojego autka
W126 380se
nr VIN: WDB1260321A11282
Proszę o pomoc.
I może ktoś wie co ile wymieniać w nim łańcuszek?
Post: pt lut 19, 2010 10:56 pm
Witam.
garnyszek pisze:
W126 380se
Podajesz niepełny numer vin.
Właściwy vin wpisz tutaj:
http://old.mbclub.ru/mb/vin/?lng=eng
garnyszek pisze:
Łańcuch rozrządu zakładany jest dożywotnio o ile sie nie myle.
sojczyn
https://t.me/pump_upp
Post: pt lut 19, 2010 11:00 pm
sojczyn pisze:
Tak - o ile wyciągnięcie nie przekroczy określonej wartości.
Mercedes podaje interwały czasu przy jakich należy je mierzyć i ew wymienić.
