Dzisiaj jest pt gru 12, 2025 5:27 am
Post: śr lis 11, 2009 4:50 pm
Co myślicie o tym autku?
http://otomoto.pl/mercedes-w124-kombi-C10547283.html
Jeździłem autem, skrzynia nie szarpie, potrzeba kilku poprawek lakierniczych, na jałowym bardzo klekocze gość mówi że to była pompa czy coś robione i trzeba zrobić 300KM i to się ułoży po lekkim dodaniu gazu klekot ustępuje.
VIN WDB1241931F209851
Model 300 TD TURBODIESEL
Chassis 1241931F209851
Engine 603960 12 037861
Transmission 722357 03 649819
Order 0 1 219 08671
Lights HELLA
Wiper BOSCH
Delivery date 11.12.91
Dealer Hamburg branch (219)
Interior fabric plaid black (371)
Paint
199 metallic blue-black (с 01.01.1983)
Options
211 automatic limited slip differential (ASD) (с 01.07.1984)
rear axle with automatic limited slip differential (ASD)
240 outside temperature indicator (с 01.03.1982)
281 trunk set, (280 SL)
steering wheel with sports design (390 mm dia.) and gearshift lever in leather trim (с 01.05.1990)
steering wheel (390 mm) with sports design (с 01.03.1989)
291 airbag for front passenger
airbag for driver and front passenger (с 01.07.1987 по 30.09.1993)
airbag for driver and front passenger (if driver airbag standard - then only for passenger)
300 storage box in front tray (с 01.05.1988)
404 orthopaedic front seat backrest (multiple contour backrest in model 140), left (с 01.04.1970 по 31.12.1995)
412 electric sliding roof with tilting device (с 01.07.1983)
440 tempomat (cruise control) (с 01.09.1975)
531 automatic antenna (с 01.01.1963)
541 double roller blind used as luggage and passenger guard (с 01.01.1980)
550 trailer coupling (с 01.03.1965)
585 Behr air conditioner and electric window lifters (front doors) (с 01.04.1970)
591 heat-insulating glass, all-around, heated rear window pane, (single-sheet safety glass), Germany
green heat-insulating glass all round, heated rear window, single pane safety glass - Germany (с 01.01.1972)
600 headlamp wiper/washer (с 01.08.1971)
620 emission control system
vehicles with catalyst technique (с 01.03.1985)
653 sports chassis with 8-hole light alloy rims (с 01.01.1990)
751 Becker radio Grand Prix 2000 vk RDS (с 01.06.1990 по 31.03.1994)
873 seat heater for left and right front seats (с 01.02.1984)
Podpowiedzcie na co zwrócić uwagę?
Jak sprawdzić turbinę?
Post: śr lis 11, 2009 6:13 pm
Daj sobie spokój z turbiną, to najmniejszy problem. Jak już chcesz to jedynie można ściągnąć gumowy dolot do niej i ręką sprawdzić czy wirnik nie ma luzu a łopatki nie są wyszczerbione.
Ważniejsze jest to co było robione z tą pompą i dlaczego. To fakt, że po różnych zabiegach auto musi przejechać 1000km i wszystko cichnie. Dowiedz się dokładnie co było naprawiane.
Post: śr lis 11, 2009 6:55 pm
tedy20 pisze:
Zastanowiłbym się także nad uszkodzonym (zużytym) popychaczem zaworowym lub napinaczem łańcucha rozrządu, ślizgami łańcucha lub samym łańcuchem.
Pozdrawia Leopold
Pozdrawia Leopold
Post: śr lis 11, 2009 7:10 pm
zapytałem i gość mi powiedział że były wymieniane uszczelniacze pompy wtryskowej <br>Dodano po 3 minutach.:<br>
leopold pisze:
Pozdrawia Leopold
Jak to poznać?
Post: śr lis 11, 2009 7:18 pm
Silnik ma 136KM, a nie 147KM to nie e-klasa. Trzeba by osłuchac silnik, może hydropopychacz stukać, albo coś innego np. wtryskiwacz. w kazdym razie podjechałbym do jakiegoś szamana, bo stuki moga okazac sie drobna pierdołą lub kosztowną usterką.
W124 200D - Śnieżyna
W124 300D - Menczysław (ex)
W123 240D - Kruszynka (ex)
Post: śr lis 11, 2009 7:44 pm
No ja bym dobrze go pooglądał ,bo na fotce która pokazuje go od tyły nie za bardzo podoba mi się linia dżwi, tak tylnych jak i przednich,popatrz szczególnie na listwy dżwiowe, coś mi tam wyje ,no ale może mi się tak wydaje !
MB 124 300 24V CE-1991 EX
MB 126 560 SEL- 1988-LPG
AUDI A3 1.6-----1997-PB
DAEWO TICO----1997-LPG
MB 126 420 SE-- 1988 EX
IVECO 3510-----1995 EX
MB 124 300 E ---1989 EX
MB 201 230 E ---1987 EX
AUDI 80 1,8E----1989 EX
SEICENTO 900---2002 - LPG
Post: śr lis 11, 2009 8:25 pm
to auto ma chyba jednak 147 KM - 136 KM miały właśnie e-klasy - tak mi się zdaje
sprawdż wnęki w bagażniku - pod zapasem i pod apteczką, pod tylnym prawym siedziskiem pod wykładziną jest pompka centralnego - obłożona gabką - sprawdz czy ta gąbka nie jest wilgotna - moze to oznaczać jakieś dziury w podłodze, zdejmij przednie dywaniki i oglądnij podłogę.
sprawdż kontrolkę od ASD i czy przed odpaleniem pali sie cały czas duża kontrolka nad licznikiem kilometrów, powinieneś mieć NIVO - sprawdź czy działa; ściągnij zaślepki w listwach progowych i oglądnij jak wyglądają otwory na lewarek (pod tymi listwami lubi gnić).
podczas jazdy posłuchaj czy na przechyłach nie piszczy wentylator nawiewu, oraz sprawdź czy działa tempomat.
sprawdź wisco na zimnym silniku i na ciepłym (oczywiście przy wyłączonym silniku :lol: )
pozdro
Suzuki Liana 1.6 '2004
124 300 TDTurbo '1991 - ex
Daihatsu Move L601 '1997 - ex
Post: śr lis 11, 2009 9:26 pm
Silnik w tym aucie ma 147 KM. 136KM ma 300D z e-klasy BEZ turbo!
tedy20 pisze:
To się trzyma kupy. W ojcowym 300Turbo też była robiona pompa i po tym zabiegu klekotał, po przejechaniu 1000km jak ręką odjął i teraz pięknie cyka.
Cena atrakcyjna i auto niczego sobie ;) Poza tym super silnik ;)
Post: śr lis 11, 2009 9:35 pm
remi pisze:
sprawdź wisco na zimnym silniku i na ciepłym (oczywiście przy wyłączonym silniku )
Popieram, ja nie sprawdzilem i teraz musze kupic nowe.
Pozatym ładnie sie prezentuje a z tym silnikem daje duzo frajdy z jazdy.
Post: śr lis 11, 2009 9:59 pm
tedy20 pisze:
Nie wiem czy zauważyłeś, ale oryginalnie to auto posiadało materiałową tapicerkę - tak przynajmniej wskazuje VIN.
w126 420sel '89
w108 280S '70
Post: pt lis 13, 2009 8:14 am
Powiedzcie czy warto pchać się w ten silnik z takim przebiegiem?
Co oznacza uszczelnianie pompy wtryskowej?
Co powiecie o tych tapicerkach bo tylko to się nie zgadza ale fotel kierowcy jest pompowany zgodnie z winem?
Proszę o pomoc i podpowiedzi, po pracy jadę oglądać auto i w razie co dokonać zakupu. <br>Dodano po 4 godzinach. 35 minutach.:<br> obejrzałem auto i do zrobienia jest:
1.dolny sworzeń wachacza lewy
2. prawy dolny sworzeń
3. tulejki wspornika drążków kierowniczych
4. teleskop poprzeczny ukł kierowniczego
5. tuleja zew stabilizatora fi=22mm -2 szt
6. opaska półośki prawej zew
7. cięgło regulacji nivo
8. tulejka wachcacza prawa
9. poduszki tylnej ławy - małe <br>Dodano po 2 godzinach. 56 minutach.:<br>
tedy20 pisze:
Sprawdziłem dalej i jest pęknięta przednia szyba, auto miało dzwona ale już nie dochodziłem co i jak, poprostu widać ze jest krzywe, jest już trochę korozji, szczególnie do okola przedniej szyby która jest pęknięta i do wymiany czyli będzie sporo roboty bo może się okazać że nie będzie miała czego się trzymć więc na tym poprzestałem sprawdzania auta bo troche tego już było za dużo <br>Dodano po 15 godzinach. 19 minutach.:<br> Zapomniałem jeszcze dodać że klima może nie działać, odniosłem takie wrażenie
