Dzisiaj jest sob sie 23, 2025 3:54 am
Post: sob lut 02, 2008 9:24 pm
VIN WDB1241931F239643
Plant 50
Model 300 TD TURBO
Chassis 1241931F239643
Engine 603960 12 043673
Transmission 722357 03 773713
Tyres
Primary DUNLOP
Order 0 2 547 10684
Lights HELLA
Wiper BOSCH
Cab 00000
Delivery date 29.10.92
Dealer Luxembourg (547)
Interior leather black / anthracite (271)
Paint
199 metallic blue-black (с 01.01.1983)
Options
202 owner's manual and maintenance booklet 1) (с 01.12.1971)
reference plate, coolant 1)
reference plate, folding top operation 1)
tire pressure instructions 1)
211 automatic limited slip differential (ASD) (с 01.07.1984)
rear axle with automatic limited slip differential (ASD)
221 left front seat, electrically adjustable (с 01.11.1978)
222 right front seat, electrically adjustable (с 01.11.1978)
228 auxiliary heater
auxiliary heater (с 01.11.1974)
auxiliary heater (only provision for installation in w 210)
240 outside temperature indicator (с 01.03.1982)
244 sports seats, front (с 01.07.1986)
281 trunk set, (280 SL)
steering wheel with sports design (390 mm dia.) and gearshift lever in leather trim (с 01.05.1990)
steering wheel (390 mm) with sports design (с 01.03.1989)
412 electric sliding roof with tilting device (с 01.07.1983)
445 steering column, electrically adjustable, and airbag (с 01.02.1980 по 31.10.1993)
481 undershields (с 01.10.1962)
531 automatic antenna (с 01.01.1963)
547 double roller blind and sun visors with mirrors on the left and right, illuminated (с 01.03.1982 по 31.07.1997)
551 anti-theft warning system (с 01.11.1978 по 31.03.1998)
580 air conditioner/Tempmatic (с 01.11.1982)
593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972)
600 headlamp wiper/washer (с 01.08.1971)
611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.1978)
653 sports chassis with 8-hole light alloy rims (с 01.01.1990)
662 20 liters of fuel (с 01.03.1986 по 30.06.1993)
673 high-capacity battery (с 01.01.1964)
682 fire extinguisher (с 01.04.1970)
724 cargo anchorage (с 01.04.1979)
731 wood trim, burred walnut root (с 01.08.1980)
752 Becker radio Mexico 2000 vk (с 01.06.1990 по 31.03.1994)
772 amg styling package - front spoiler, side skirts and rear apron (с 02.01.1992)
873 seat heater for left and right front seats (с 01.02.1984)
910 14V/65A alternator
alternator with increased capacity (с 01.11.1990)
953 rotating emergeny flasher, central front (blue light)
sportline with 8-hole rim (consisting of codes 65/3, 244, 281) (с 01.02.1991 по 30.09.1996)
Post: ndz lut 03, 2008 10:47 am
VIN - WDB1241931F239643
Model - 300 TD TURBO
Nadwozie - 1241931F239643
Silnik - 603960 12 043673
Skrzynia - 722357 03 773713
Opony - Dunlop
Zamówienie - 0 2 547 10684
Światła - HELLA
Wycieraczka - BOSCH
Dostawa - 29.10.92
Dealer - Luksemburg
Tapicerka - czarna skóra
Lakier - 199 ciemno-niebieski metallic
202 - książka serwisowa
211 - blokada mostu ASD
221 - elektryczny fotel kierowcy
222 - elektryczny fotel pasażera
228 - dodatkowe ogrzewanie
240 - termometr zewnętrzny
244 - przednie fotele sportowe
281 - sportowa kierownica i dźwignia biegów w skórze
412 - szyberdach elektryczny
445 - elektrycznie regulowana kolumna kierownicy + poduszka
481 - stalowa osłona pod silnikiem
531 - elektryczna antena
547 - osłony przeciwsłoneczne z lusterkami i podświetlaniem
551 - alarm fabryczny
570 - składany podłokietnik
580 - klimatyzacja + tempmatik
593 - szyby termoizolacyjne + tylna szyba ogrzewana
600 - wycieraczki na reflektorach
611 - lampki u dołu drzwi
653 - alufelgi 8-mio dziurowe
662 - 20 litrów paliwa
673 - akumulator o dużej pojemności
682 - gaśnica
724 - uchwyty ładunkowe
731 - środek wykończony w drewnie orzechowym
752 - radio Becker Meksyk 2000
772 - stylizacja zderzaków i listew na AMG
873 - przednie fotele podgrzewane
910 - alternator 14V/65A
953 - wersja sportline
Ostatnio zmieniony ndz lut 03, 2008 7:41 pm przez Mirmur, łącznie zmieniany 3 razy.
Post: ndz lut 03, 2008 12:00 pm
Mirmur pisze:
580 - klimatyzacja + tempomat
To nie tempomat tylko tempmatic nie wiem dokladnie co i jak bo to nie czesty badziew i w sumie widzialem tylko panel od tego ale jest to do kontroli klimatu w aucie.
Mirmur pisze:
prawie cały możliwy wypas dostępny dla tego modelu
jak na moj gust to brakuje conajmniej kilkunastu kodow w tym kilku dosc typowych chocby elektryki szyb i lusterek.
Ale jak
przetlumaczyles na
662 - dodatkowy kanister 20l
Toyota MR2 2,0 '93
Ex: W124 300E 4matic '87
Post: ndz lut 03, 2008 12:35 pm
Na sprzedaż?
Post: ndz lut 03, 2008 12:44 pm
Mirmur pisze:
953 - niebieski ''kogut'' z przodu
http://w114-115.org.pl/forum/viewtopic. ... highlight=
R 107 E 45 ,W 123 ???,EX:42MB
Jurek tel: 880-310-005
Post: ndz lut 03, 2008 1:39 pm
Bardzo dziękuję. Chyba się na niego skuszę - co o tym myślisz RoadRunner?
Post: ndz lut 03, 2008 2:37 pm
alter pisze:
Przyjedz to sie go ogladnie po kodach to ja aut nie kupuje [zlosnik]
Toyota MR2 2,0 '93
Post: ndz lut 03, 2008 7:20 pm
Poprawiłem tłumaczenie VIN tego MB według Waszych sugestii. Faktycznie brak w tym VIN elektryki szyb i lusterek.
