Czy ktoś oglądał to auto?
Zamierzam je kupić. Cena 18.000zł + wszystkie opłaty
Przebieg ok. 185.000km z roku 94'
VIN WDB1240421C151774
Model E220C
Chassis 1240421C151774
Engine 111960 10 028861
Transmission 717413 06 556027
Order 0 4 513 17529
Approx. year 1994
Dealer Belgium (513)
Interior leather mushroom (265)
Paint
199 metallic blue-black (с 01.01.1983)
Options
260 elimination of model designation on rear lid (с 01.05.1968)
281 trunk set, (280 SL)
steering wheel with sports design (390 mm dia.) and gearshift lever in leather trim (с 01.05.1990)
steering wheel (390 mm) with sports design (с 01.03.1989)
291 airbag for front passenger
airbag for front passenger (с 01.10.1993)
airbag for driver and front passenger (if driver airbag standard - then only for passenger)
300 storage box in front tray (с 01.05.1988)
430 headrests in the rear (с 01.01.1977)
538 automatic antenna and front loudspeaker - without radio set (model 500SEC with loudspeaker only) (с 01.10.1989)
585 Behr air conditioner and electric window lifters (front doors) (с 01.04.1970)
592 heat-insulating glass, all-around, heated rear window pane (laminated glass), band filter
green heat-insulating glass all round, heated rear window, laminated safety glass - tinted strip (с 01.01.1972)
611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.1978)
620 emission control system
vehicles with catalyst technique (с 01.03.1985)
630 ECE warning triangle (с 01.08.1980)
731 wood trim, burred walnut root (с 01.08.1980)
866 Technical changes of modelling year 1995 (с 01.01.1994 по 19.10.1997)
Co o tym sądzicie? Mi się podoba, ale wolę zapytać
bo jak człowiek się napali to kiepsko z głową hehe
Jeszcze go nie oglądałem, ale wkrótce mam zamiar.
