Dzisiaj jest śr sie 27, 2025 4:16 am
Post: czw kwie 05, 2007 8:33 pm
WDB1241901F065905 z gory dziekuje
124-250 TD. 1989r.
Fso syrena r-20. 1980 r.
Toyota yaris. 1999r.
Post: czw kwie 05, 2007 8:56 pm
VIN WDB1241901F065905
Plant 67
Model 300 TD
Chassis 1241901F065905
Engine 603912 12 025504
Transmission 722415 02 593323
Tyres
Primary CONTINENTAL
Order 0 9 293 06331
Lights HELLA
Cab 00264
Delivery date 04.02.88
Dealer company vehicle (293)
Interior cloth mushroom (075)
Paint
355 diamond blue metallic (1984-1990, с 1994)
Options
211 automatic limited slip differential (ASD) (с 01.07.1984)
rear axle with automatic limited slip differential (ASD)
221 left front seat, electrically adjustable (с 01.11.1978)
222 right front seat, electrically adjustable (с 01.11.1978)
240 outside temperature indicator (с 01.03.1982)
404 orthopaedic front seat backrest (multiple contour backrest in model 140), left (с 01.04.1970 по 31.12.1995)
412 electric sliding roof with tilting device (с 01.07.1983)
420 automatic transmission, floor shift (с 01.01.1963)
470 anti-lock braking system (abs) (с 01.06.1978 по 31.10.1993)
511 Becker radio Grand Prix cassette electronic stereo, Kurier, LW/MW/USW (с 01.11.1982 по 30.11.1990)
Becker radio Mexico cassette full stereo
Becker radio Monza cassette stereo LW/MW/SW/USW
531 automatic antenna (с 01.01.1963)
583 electric window lifters (front doors) (с 01.04.1970)
591 heat-insulating glass, all-around, heated rear window pane, (single-sheet safety glass), Germany
green heat-insulating glass all round, heated rear window, single pane safety glass - Germany (с 01.01.1972)
600 headlamp wiper/washer (с 01.08.1971)
645 M+S tires (с 01.10.1963)
682 fire extinguisher (с 01.04.1970)
812 rear-mounted loudspeaker (с 01.11.1974)
873 seat heater for left and right front seats (с 01.02.1984)
Post: czw kwie 05, 2007 9:05 pm
Wyszło mi dokładnie to samo :.
Plant 67
Model 300 TD
Tyres
Primary CONTINENTAL
Order 0 9 293 06331
Lights HELLA
Cab 00264
Paint
Options
I teraz takie pytanie mam odnoście sprawdzania VIN'u .
http://w114-115.org.pl/forum/viewtopic.php?t=5342
Robie tak, że wchodze na tą stronę, http://www.mbclub.ru/mb/vin/?lng=eng wpisuje VIN i klikam full wersion, i kopiuje to co wyjdzie i wklejam na forum, Wy też tak robicie ??, dobrze robię ?? .
 Tytuł: W124
Post: czw kwie 05, 2007 11:37 pm
Żeluś zmiłuj się.
Post: pt kwie 06, 2007 8:56 am
Żeluś pisze:
Jak wyszło Ci to samo, to po co wklejać dwa takie same rozkodowane VIN'y? :roll:
S123 300TD
Post: pt kwie 06, 2007 9:11 am
Żeluś wkleiles taki sam VIN i wyszlo Ci tak samo?
Az nie moge uwiezyc! [zlosnik] [zlosnik] [zlosnik]
"Think Locally,
Fuck Globally"
Kiedyś:
Dziś:
Post: pt kwie 06, 2007 1:37 pm
OK macie racje mogłem nie wklejac tego VIN'u. Przepraszam.
MajsterGarage pisze:
Żeluś pisze:
http://w114-115.org.pl/forum/viewtopic. ... &&start=15
MajsterGarage zadam Ci podobne pytanie ( bez rzadnych złośliwości ) jak wszyscy umieją czytac to po co pisac taki post jak w tym temacie, który wyżej wkleiłem ?? :roll: :roll: .
