Dzisiaj jest sob sie 30, 2025 1:55 pm
Post: pn lip 03, 2006 8:43 pm
Witam!
Kto ma niedaleko i mógłby obejrzeć, bo na fotkach wygląda zachęcająco: http://www.otomoto.pl/index.php?sect=show&id=C1259296
VIN WDB1241331B718021
Model 300 D TURBO
Chassis 1241331B718021
Engine 603960 12 039478
Transmission 722357 03 680394
Order 0 2 559 20095
Approx. year 1992
Lights BOSCH
Wiper BOSCH
Cab 00694
Dealer Poland (559)
Interior leather mushroom (265)
Paint
249 malachite metallic (с 01.01.1990 по 31.12.1996)
Options
211 automatic limited slip differential (ASD) (с 01.07.1984)
rear axle with automatic limited slip differential (ASD)
240 outside temperature indicator (с 01.03.1982)
280 steering wheel (400 mm dia.) and gearshift lever in leather trim; on W202 390 mm dia. (с 01.05.1984)
404 orthopaedic front seat backrest (multiple contour backrest in model 140), left (с 01.04.1970 по 31.12.1995)
412 electric sliding roof with tilting device (с 01.07.1983)
442 airbag in steering wheel (с 01.02.1980 по 31.10.1993)
481 undershields (с 01.10.1962)
538 automatic antenna and front loudspeaker - without radio set (model 500SEC with loudspeaker only) (с 01.10.1989)
540 roller blind, electric, for rear window (с 01.05.1985)
588 automatic climate control and electric window lifters (front and rear doors) (с 01.01.1977)
592 heat-insulating glass, all-around, heated rear window pane (laminated glass), band filter
green heat-insulating glass all round, heated rear window, laminated safety glass - tinted strip (с 01.01.1972)
600 headlamp wiper/washer (с 01.08.1971)
673 high-capacity battery (с 01.01.1964)
812 rear-mounted loudspeaker (с 01.11.1974)
837 rubber mats on front floor and rear floor; with chassis, front only; with station wagon, including loading floor (с 01.11.1969)
Przebieg 430 000 (przy 300 000 robiony remont generalny silnika). 4 opony letnie do wymiany. Do wywalenia: białe kierunki, felgi, gałka zmiany biegów.
Właściciel rzeczowy. Jeżeli stan jest taki jak na fotkach i to ja jestem zainteresowany :D
Z góry dzięki za pomoc!
Chłopaki pomóżcie. Nikt nie jest z Katowic? :(
Post: wt lip 04, 2006 2:56 am
Krzychu zaden problem :D bierzemy dziewczyny (nasze) do samochodu i jedziemy do Katowic nawet jutro :D przy mojej jezdzie pare godzin i na miejscu :D
!!!ZWOLNIJ SZKODA ŻYCIA!!!
W124 TDT 3.0 1988r. "mała" - automat - na sprzedaz
Cadillac Brougham 5.0 1989r."czarny" - automat
Post: wt lip 04, 2006 6:24 am
Biorac pod uwage ze przez 14 lat byl eksploatowany na polskich drogach to bym sobie odpuscil.
Ex: 1987 MB W201 2.5D ''Niebieski Rekin'' :( - zawsze w mojej pamięci.
Obecnie: FF '07 1.6 TDCi - też się kula ;)
Post: wt lip 04, 2006 8:07 pm
I ten przebieg przy turbo nie wrozy nic dobrego. Zreszta był remontowany....
'02 BMW E46 320td Compact
'03 MB Sprinter 413CDI SprintShift
'00 Seat Leon 1M AHF - ex
'02 Seat Ibiza 1.9SDI 6k2 - ex
'94 MB W124 E300DT- ex
W poszukiwaniu swojej gwiazdy!
