Dzisiaj jest ndz gru 14, 2025 6:28 pm
Post: czw cze 02, 2005 11:23 pm
prosze o rozkodowanie vin mb 190 z 89 roku WBD2010291F555882 . dzieki
VW Passat B5 1,9TDI AFN `97
MB201 190E 2,3-16v 185 KM, FULL `85
VW Golf 1,9TDI ALE `97 - EX
MB201 190E 2.0 88r automat leniuch - EX
MB123 240D 79r - EX
dawniej FIAT 126p 'czerwona strzala' 87-88r - EX
Post: czw cze 02, 2005 11:32 pm
jesteś pewien że z 89-tego?
tutaj:
http://www.vehicleidentificationnumber. ... -benz.html
wyskakuje tak:
VIN WBD2010291F555882
Year of Manufacture 2001
Chassis Code 201
Manufacturer Name BD
Model 190 E 2.6
Restraint Systems
Displacement
Horsepower
Fuel Diesel
Production Plant Bremen
Country of Manufacture Germany
Production No. 555882
a tutaj:
http://www.analogx.com/cgi-bin/cgivin.e ... mit=Decode
tak:
Vehicle Identification Number:
Description Position Raw Data Decoded Data
Region: 1 W Europe
Country: 1-2 WB Germany
Manufacturer: 2-3 BD Unknown
Model Specific: 4-8 20102 Unknown
Check Digit: 9 9 Invalid
Year: 10 1 2001
Assembly Plant: 11 F F
Serial Number: 12-17 555882 555882
a u kolegów z MB Russia tak;
Datacard WBD2010291F555882 not found
1) VIN was incorrectly introduced in the form of demand;
2) VIN was incorrectly rewritten from the documents or from the body of automobile;
3) VIN was changed in the documents or on the body by criminals. :o
S1
Ostatnio zmieniony czw cze 02, 2005 11:41 pm przez Samsung1, łącznie zmieniany 1 raz.
Post: czw cze 02, 2005 11:40 pm
VIN WDB2010291F555882
Model 190 E 2.6
nr nadwozia: 2010291F555882
nr silnika: 103942 10 011666
skrzynia: 717435 01 141495 ->manualna 5 biegów
zamówienie: 0 7 287 90726 ->1987r
Approx. year 1987
Lights BOSCH
Wiper BOSCH
Dealer authorities sales (287)
tapicerka: cloth black (061)
kolor:147 arctic white (T) (с 01.01.1985 по 31.12.1993)
Options
211 automatic limited slip differential (ASD) (с 01.07.1984)
rear axle with automatic limited slip differential (ASD)
228 auxiliary heater
auxiliary heater (с 01.11.1974)
auxiliary heater (only provision for installation in w 210)
240 outside temperature indicator (с 01.03.1982)
243 sports seats, front and rear (с 01.12.1986)
260 elimination of model designation on rear lid (с 01.05.1968)
261 elimination of model designation V12 (с 01.11.1973)
280 steering wheel (400 mm dia.) and gearshift lever in leather trim; on W202 390 mm dia. (с 01.05.1984)
412 electric sliding roof with tilting device (с 01.07.1983)
430 headrests in the rear (с 01.01.1977)
506 outside rear view mirror, left and right, heated (electrically adjustable on the right) (l.h.d.) (с 01.10.1983 по 31.03.1989)
outside rear view mirror, right, convex, taxi export version
534 antenna, mechanically operated, without radio set (с 01.01.1963 по 30.11.1990)
543 sun visor with vanity mirror, illuminated, left and right (с 01.11.1978)
572 front seat, right, with seat height adjustment; l.h.d. (с 01.08.1975)
586 Behr air conditioner, and electric window lifters (front and rear doors) (с 01.04.1970)
591 heat-insulating glass, all-around, heated rear window pane, (single-sheet safety glass), Germany
green heat-insulating glass all round, heated rear window, single pane safety glass - Germany (с 01.01.1972)
620 emission control system
vehicles with catalyst technique (с 01.03.1985)
645 M+S tires (с 01.10.1963)
673 high-capacity battery (с 01.01.1964)
682 fire extinguisher (с 01.04.1970)
876 rear door contaCTS and lamp above rear window (с 01.07.1964 по 31.10.1993)
915 Unknown code
124 E220 coupe 96'FOTO
MB artykuły prasowe cz1
MB artykuły prasowe cz2
Post: czw cze 02, 2005 11:46 pm
VALENTINE123 pisze:
Approx. year 1987
czyli nie 89
S1
Post: czw cze 02, 2005 11:51 pm
Jak moze byc model 190E 2,6 w dieslu?
wyglada on tak:
martwi mnie to:
i co wy na to? Prosze o porady. (moge go kupic za 1300E)
MB123 240D 79r - EX
Post: czw cze 02, 2005 11:59 pm
Samsung1 pisze:
VALENTINE123 pisze:
Approx. year 1987
czyli nie 89
S1
87 to rok zlozenia zamowienia
Post: pt cze 03, 2005 12:02 am
Konri pisze:
W sumie cena jest pewnie odzwierciedleniem stanu, ale na fotkach nie jest zle, a troche rudego pod plastikami to znajdziesz prawie na kazdym (16 lat swoje robi). Fajnie wyposazenie, a choc cos z niego dziala [oczko] ?
Jak dlugo to auto czeka na nabywce?
Post: pt cze 03, 2005 12:05 am
Wlasnie dziala wszystko. Nawet podswietlenie lusterek w oslonach przeciwslonechnych. :) Tylko ten silnik 2,6! (ma apetyt) :(
MB123 240D 79r - EX
Post: pt cze 03, 2005 12:09 am
Samsung1 pisze:
czyli nie 89
S1
Co do daty produkcji ,to na podstawie tabliczki lakierowanej wychodzi mi 88' ,a na podstawie tabeli z numerami produkcyjnymi wychodzi przełom września-października 88'.Także podany 89' jest to data pierwszej rejestracji.
Post: pt cze 03, 2005 12:15 am
Wszystko sie zgadza.
Po prostu konri błędnie podał numer (czeski błąd) - przestawione trzy pierwsze znaki:
Konri pisze:
prosze o rozkodowanie vin mb 190 z 89 roku WBD 2010291F555882 . dzieki
nie zwróciłem na to uwagi :roll: a Valentine to wychwycił :)
S1
Post: pt cze 03, 2005 12:26 am
Oczywiscie! Powinno byc 'WDB...' moj blad :) Czy moze mi ktos to przetlumaczyc bo nie wszystko jest dla mnie jasne?
MB123 240D 79r - EX
Post: pt cze 03, 2005 12:44 am
Wypas:
211-blokada dyferencjału(mostu) ,czyli ASD
228-webasto
240-wskaźnik temperatury zewnętrznej
243-sportowe siedzenia ,przód i tył
260-brak znaczka na tylniej klapie
261 ???
280 kierownica 400mm i drzwidnia biegów w skórze
412-el. szyber dach
430-zagłówki z tyłu
506-el regulowane i podgrzewane lusterka
534 antena wysuwana ręcznie ,bez radia
543-lusterka w osłanach przeciwsłonecznych podświetlane
572-fotel kierowcy z regulacją wysokości
586-klima i el podnoszone szyby
591-szyby atermiczne
620-katalizator
645-opony zimowe
673-akumulator o podwyższonej pojemności
682 gaśnica
876 -dadatkowe załączanie lampek w tylnich dzwiach
915 -bak 70 litrów
Post: pt cze 03, 2005 2:33 am
Konri pisze:
webasto tez?
Post: pt cze 03, 2005 7:37 am
Widziałem co potrafi zrobić taka 2.6E .... dym z opon utrzymywał sie przez 40 minut a ślady 1,5 miesiąca [zlosnik]
Pozdrowki
adi
Post: pt cze 03, 2005 10:08 am
adi pisze:
to nieźle ktoś się nudził :lol: :lol: :lol: :lol:
MB W202 '97 200 KOMPRESSOR
