| Czy może ktoś przetłumaczyć VIN (bardzo ciekawy egzemplarz) https://forum.w114-115.org.pl/viewtopic.php?f=25&t=31536 |
| Autor: | alter [ sob lut 02, 2008 9:24 pm ] |
| Tytuł: | Czy może ktoś przetłumaczyć VIN (bardzo ciekawy egzemplarz) |
VIN WDB1241931F239643 Plant 50 Model 300 TD TURBO Chassis 1241931F239643 Engine 603960 12 043673 Transmission 722357 03 773713 Tyres Primary DUNLOP Order 0 2 547 10684 Lights HELLA Wiper BOSCH Cab 00000 Delivery date 29.10.92 Dealer Luxembourg (547) Interior leather black / anthracite (271) Paint 199 metallic blue-black (с 01.01.1983) Options 202 owner's manual and maintenance booklet 1) (с 01.12.1971) reference plate, coolant 1) reference plate, folding top operation 1) tire pressure instructions 1) 211 automatic limited slip differential (ASD) (с 01.07.1984) rear axle with automatic limited slip differential (ASD) 221 left front seat, electrically adjustable (с 01.11.1978) 222 right front seat, electrically adjustable (с 01.11.1978) 228 auxiliary heater auxiliary heater (с 01.11.1974) auxiliary heater (only provision for installation in w 210) 240 outside temperature indicator (с 01.03.1982) 244 sports seats, front (с 01.07.1986) 281 trunk set, (280 SL) steering wheel with sports design (390 mm dia.) and gearshift lever in leather trim (с 01.05.1990) steering wheel (390 mm) with sports design (с 01.03.1989) 412 electric sliding roof with tilting device (с 01.07.1983) 445 steering column, electrically adjustable, and airbag (с 01.02.1980 по 31.10.1993) 481 undershields (с 01.10.1962) 531 automatic antenna (с 01.01.1963) 547 double roller blind and sun visors with mirrors on the left and right, illuminated (с 01.03.1982 по 31.07.1997) 551 anti-theft warning system (с 01.11.1978 по 31.03.1998) 570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970) front folding armrest w202 - housing at front with armrest 580 air conditioner/Tempmatic (с 01.11.1982) 593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972) 600 headlamp wiper/washer (с 01.08.1971) 611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.1978) 653 sports chassis with 8-hole light alloy rims (с 01.01.1990) 662 20 liters of fuel (с 01.03.1986 по 30.06.1993) 673 high-capacity battery (с 01.01.1964) 682 fire extinguisher (с 01.04.1970) 724 cargo anchorage (с 01.04.1979) 731 wood trim, burred walnut root (с 01.08.1980) 752 Becker radio Mexico 2000 vk (с 01.06.1990 по 31.03.1994) 772 amg styling package - front spoiler, side skirts and rear apron (с 02.01.1992) 873 seat heater for left and right front seats (с 01.02.1984) 910 14V/65A alternator alternator with increased capacity (с 01.11.1990) 953 rotating emergeny flasher, central front (blue light) sportline with 8-hole rim (consisting of codes 65/3, 244, 281) (с 01.02.1991 по 30.09.1996) |
| Autor: | Mirmur [ ndz lut 03, 2008 10:47 am ] |
VIN - WDB1241931F239643 Model - 300 TD TURBO Nadwozie - 1241931F239643 Silnik - 603960 12 043673 Skrzynia - 722357 03 773713 Opony - Dunlop Zamówienie - 0 2 547 10684 Światła - HELLA Wycieraczka - BOSCH Dostawa - 29.10.92 Dealer - Luksemburg Tapicerka - czarna skóra Lakier - 199 ciemno-niebieski metallic 202 - książka serwisowa 211 - blokada mostu ASD 221 - elektryczny fotel kierowcy 222 - elektryczny fotel pasażera 228 - dodatkowe ogrzewanie 240 - termometr zewnętrzny 244 - przednie fotele sportowe 281 - sportowa kierownica i dźwignia biegów w skórze 412 - szyberdach elektryczny 445 - elektrycznie regulowana kolumna kierownicy + poduszka 481 - stalowa osłona pod silnikiem 531 - elektryczna antena 547 - osłony przeciwsłoneczne z lusterkami i podświetlaniem 551 - alarm fabryczny 570 - składany podłokietnik 580 - klimatyzacja + tempmatik 593 - szyby termoizolacyjne + tylna szyba ogrzewana 600 - wycieraczki na reflektorach 611 - lampki u dołu drzwi 653 - alufelgi 8-mio dziurowe 662 - 20 litrów paliwa 673 - akumulator o dużej pojemności 682 - gaśnica 724 - uchwyty ładunkowe 731 - środek wykończony w drewnie orzechowym 752 - radio Becker Meksyk 2000 772 - stylizacja zderzaków i listew na AMG 873 - przednie fotele podgrzewane 910 - alternator 14V/65A 953 - wersja sportline Pozdrawiam. |
| Autor: | roadrunner [ ndz lut 03, 2008 12:00 pm ] |
Mirmur pisze: 580 - klimatyzacja + tempomat To nie tempomat tylko tempmatic nie wiem dokladnie co i jak bo to nie czesty badziew i w sumie widzialem tylko panel od tego ale jest to do kontroli klimatu w aucie. Mirmur pisze: prawie cały możliwy wypas dostępny dla tego modelu jak na moj gust to brakuje conajmniej kilkunastu kodow w tym kilku dosc typowych chocby elektryki szyb i lusterek. Ale jak Cytuj: 662 20 liters of fuel przetlumaczyles na Cytuj: 662 - dodatkowy kanister 20l
| Autor: | Jarzyn [ ndz lut 03, 2008 12:35 pm ] |
Na sprzedaż? |
| Autor: | adler1934 [ ndz lut 03, 2008 12:44 pm ] |
Mirmur pisze: 953 - niebieski ''kogut'' z przodu
http://w114-115.org.pl/forum/viewtopic. ... highlight= |
| Autor: | alter [ ndz lut 03, 2008 1:39 pm ] |
Bardzo dziękuję. Chyba się na niego skuszę - co o tym myślisz RoadRunner? |
| Autor: | roadrunner [ ndz lut 03, 2008 2:37 pm ] |
alter pisze: co o tym myślisz RoadRunner?
Przyjedz to sie go ogladnie po kodach to ja aut nie kupuje
| Autor: | Mirmur [ ndz lut 03, 2008 7:20 pm ] |
Poprawiłem tłumaczenie VIN tego MB według Waszych sugestii. Faktycznie brak w tym VIN elektryki szyb i lusterek. Pozdrawiam. |
