| dacie radę z tym VIN-em? https://forum.w114-115.org.pl/viewtopic.php?f=25&t=30493 |
| Autor: | m_slonik [ śr gru 12, 2007 12:51 am ] |
| Tytuł: | dacie radę z tym VIN-em? |
WDB1240231A661767 z góry dziękuję! |
| Autor: | AndyS [ śr gru 12, 2007 1:17 am ] |
VIN WDB1240231A661767 Model 230 E Chassis 1240231A661767 Engine 102982 10 089618 Transmission 717412 00 917753 Order 0 7 220 03894 Approx. year 1987 Lights HELLA Wiper SWF Cab 42642 Dealer Hannover branch (220) Interior fabric gray or alpaca gray (078) Paint 199 metallic blue-black (с 01.01.1983) Options 211 automatic limited slip differential (ASD) (с 01.07.1984) rear axle with automatic limited slip differential (ASD) 254 Becker radio Europa Kurier cassette (с 01.06.1978 по 30.11.1990) 404 orthopaedic front seat backrest (multiple contour backrest in model 140), left (с 01.04.1970 по 31.12.1995) 412 electric sliding roof with tilting device (с 01.07.1983) 428 manual five-speed transmission (с 01.01.1970) 430 headrests in the rear (с 01.01.1977) 466 central locking system (с 01.04.1970 по 31.10.1993) 470 anti-lock braking system (abs) (с 01.06.1978 по 31.10.1993) 506 outside rear view mirror, left and right, heated (electrically adjustable on the right) (l.h.d.) (с 01.10.1983 по 31.03.1989) outside rear view mirror, right, convex, taxi export version 570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970) front folding armrest w202 - housing at front with armrest 590 heat-insulating glass, all-around, heated rear window pane (laminated glass), Germany green heat-insulating glass all round, heated rear window, laminated safety glass - Germany (с 01.01.1972) 620 emission control system vehicles with catalyst technique (с 01.03.1985) 645 M+S tires (с 01.10.1963) 682 fire extinguisher (с 01.04.1970) 812 rear-mounted loudspeaker (с 01.11.1974) 873 seat heater for left and right front seats (с 01.02.1984) |
| Autor: | m_slonik [ śr gru 12, 2007 1:26 am ] |
da radę po po Polsku? będe wdzięczny <br>Dodano po 1 minutach.:<br> co oznaczaja daty w nawiasach???? |
| Autor: | witek-sec [ śr gru 12, 2007 11:18 am ] |
Prosze tlumaczenie s_lonik ale tak na wesolo (bo na smutno mi sie nie chce ) Pracownik przeprowadzający zagraniczne operacje dewizowe Hannover gałąź (220) Wnętrze tkanina szary albo alpaka szary (078) Farba 199 metaliczny niebieski - czarny ( 01.01.1983) Opcje 211 automatyczny spółka z ograniczoną odpowiedzialnością pośliznąć się zróżnicowany ASD ) ( 01.07.1984) tył oś rezygnować automatyczny spółka z ograniczoną odpowiedzialnością pośliznąć się zróżnicowany ASD ) 254 Skinienie radio Euroobligacja Kurier kaseta ( 01.06.1978 30.11.1990) orthopaedic przód siedziba backrest ( wieloraki nawiązywać kontakt backrest w model 140), zostawiać ( 01.04.1970 31.12.1995) 412 elektryczny ślizganie się dach rezygnować przechylanie pomysł ( 01.07.1983) 428 ręczny pięć - szybkość transmisja ( 01.01.1970) 430 podgłówek w tyle ( 01.01.1977) 466 środkowy zatrzaskiwanie system ( 01.04.1970 31.10.1993) 470 anty - zamek hamowanie system ( wartość bezwzględna ) ( 01.06.1978 31.10.1993) 506 zewnątrz lusterko wsteczne , zostawiać i prawy , ożywiony ( elektrycznie dostosowywalny od prawy ) (l.h.d.) ( 01.10.1983 31.03.1989) zewnątrz lusterko wsteczne , prawy , wypukły , nakładanie podatków wywóz wersja 570 teczka podłokietnik przód w202/210 załadowanie pudło przód rezygnować podłokietnik ( 01.04.1970) przód teczka podłokietnik w202 mieszkaniowy przy przód rezygnować podłokietnik 590 upał - izolowanie szkło , wszystko - wokoło , ożywiony tylna szyba szyba okienna ( pokryte blaszkami szkło ), Niemcy zieleń upał - izolowanie szkło wszystko pełny pakiet , ożywiony tylna szyba , pokryte blaszkami kasa szkło Niemcy ( 01.01.1972) 620 wypuszczenie system sterowania pojazdy rezygnować katalog technika ( 01.03.1985) MS + męczy ( 01.10.1963) 682 zapalić gaśnica ( 01.04.1970) 812 tył - konny głośnik ( 01.11.1974) 873 siedziba kaloryfer pod kątem zostawiać i prawy przód siedzenia ( 01.02.1984) |
| Autor: | Mor [ śr gru 12, 2007 2:43 pm ] |
witek-sec pisze: automatyczny spółka z ograniczoną odpowiedzialnością (...)
To ciekawy wypas ma to auto
| Autor: | m_slonik [ śr gru 12, 2007 2:48 pm ] |
się pośmiałem czytajac ale da rade tak bez jaj? bo w niektórych momentach to się głowię! <br>Dodano po 58 sekundach.:<br> i ponawiam pytanie o daty z nawiasów????
| Autor: | mindo [ śr gru 12, 2007 3:50 pm ] |
daty z nawiasow - od kiedy do kiedy wystepowalo dane wyposazenie |
| Autor: | m_slonik [ śr gru 12, 2007 11:38 pm ] |
no nie badzcie tacy? napiszcie mi normalnie po polsku. hmmmmmm...??? |
| Autor: | Mor [ czw gru 13, 2007 7:54 am ] |
Tak z grubsza, może coś ktoś poprawi: 1) ASD - taka blokada mechanizmu różnicowego - jest o niej wiele na forum napisane 2) radio kasetowe Becker Europa Kurier 3) siedzenie kierowcy ortopedyczne - pompowane w potocznym języku - jest sterowniczek mały przy zapięciu od pasów bezpieczeństwa 4) elektr. szyberdach 5) 5-biegowa skrzynia manual 6) zagłówki z tyłu 7) centralny zamek 8 ) ABS 9) oba lusterka zewnętrzne grzane, prawe regulowane elektr. 10) podłokietnik z przodu 11) szyby atermiczne, tylna szyba ogrzewana z laminacją (chyba chodzi o ten typ co ma tendencje do rozwarstwiania) 12) katalizator 13) opony zimowe 14) gaśnica 15) głośniki z tyłu 16) grzanie tyłka na przednich siedzeniach (oparcia też |
| Autor: | m_slonik [ czw gru 13, 2007 3:25 pm ] |
no dzięki wielkie! to by się wszystko zgadzało Tezaz załatwiłem sobie kołpaki do mojego 124 i podobno są z zoku 88r. mozliwe to?? to sa takie standardowe jak sie widuje w 124 Acha i tylna szyba faktycznie sie rozwarstwia!
| Autor: | m_slonik [ pt gru 14, 2007 8:09 pm ] |
I jeszcze takie pytanko- czy 124 sedany miały montowane NIVO? Niedawno byłem szczęśliwym posiadaczem W123 sedana który NIVO miał
teraz mam 124 który ma po lewej stronie taki dziwny zbiorniczek co wyglada jak od NIVO! <br>Dodano po 58 sekundach.:<br> 124 sedan oczywiście |
| Autor: | DJ_Mouse [ ndz gru 16, 2007 12:17 pm ] |
Cytuj: 506 outside rear view mirror, left and right, heated (electrically adjustable on the right) (l.h.d.) (с 01.10.1983 по 31.03.1989)
outside rear view mirror, right, convex, taxi export version Panowie wytłumaczcie mi coś... czy kod 506 a właściwie koniec jego tłumaczenia (taxi export version) Znaczy, że autko wyjechało z fabryki jako taryfa?? Mam 2 124 i w Vinie każdego z nich mam właśnie ten kod... Autka są w super stanie i zastanawia mnie to cały czas... Czy taxówki nie powinny mieć innego tunelu środkowego?? Wczoraj byłem na złomie po ogranicznik i wyjmowałem sobie go właśnie z taryfy (inny środkowy tunel, lampka w podsufitce i jeszcze kilka drobiazgów) ale u mnie nic z tych rzeczy nie ma... Jak mam sobie to tłumaczyć?? |
