| [W124] Płyn do chłodnicy https://forum.w114-115.org.pl/viewtopic.php?f=25&t=18627 |
| Autor: | janus [ pt maja 05, 2006 9:44 pm ] |
| Tytuł: | [W124] Płyn do chłodnicy |
Niebawem zamierzam wymienić płyn w chłodnicy jednak nie wiem ile go tam wchodzi będę wdzięczny za podpowiedz. Jeszcze jedna sprawa chce kupic płyn mobil 911 plus jakoś w necie nigdzie go nie widze a po sklepach jeszcze nie chodziłem ciężko jest go znaleść (Poznań, Konin)? Jeśli tak to czy wiecie gdzie można w necie go zamówic ? |
| Autor: | WeebShut [ sob maja 06, 2006 8:14 am ] |
Type 200 CE Name 200 CE Name Mercedes-Benz type 200 CE Short name 200 CE Model C 124 E 20 Production 03.90/06.90 - 12.92 Number produced 5.921 Comments concerning the production period begin of production - pre-production batch / main production - end of production Prices not available in Germany Wheelbase 2715 mm Track rear/front 1501/1491 mm ("Sportline": 1518/1509 mm) Length 4655 mm Width 1740 mm Height 1394 mm ("Sportline": 1375 mm) Smallest turning circle 10,99 m Chassis weight ========== Max. total weight 1850 kg Max. front axle weight 910 kg Max. rear axle weight 940 kg Max. load 530 kg Max. trailer weight braked 1500 kg Max. trailer weight unbraked 715 kg Weight empty 1360 kg According to guideline DIN 70020 (with fuel, spare wheel and tool equipment) Operating method four-stroke Otto (w/ manifold-injection; emission control device w/ three-way catalyst on demand) Configuration front, parallel; upright Type M 102 E 20 / 102.963 No. of cylinder/configuration 4 / in line; 15ř inclination to the right Bore x stroke 89,0 x 80,2 mm Total displacement 1996 ccm Compression ratio 9,1 Crankshaft bearing 5 Output 122 hp / 90 kW at 5100 /min (with catalyst 118 hp / 87 kW at 5200 /min) Maximum torque 178 Nm (with catalyst 172 Nm) at 3500 /min No. of valves/configuration 1 intake, 1 exhaust / V-shaped overhead Valve operation top camshaft Camshaft drive simple roller-type chain Mixture formation manifold-injection, mechano-electronically controlled (Bosch KE-Jetronic) Cooling water cooling / pump; 8,5 l water Lubrication pressure circulation lubrication / 5 l oil Electric system 12 V Battery 62 Ah / in the engine compartment Dynamo three-phase AC / 980 W Starter motor electrical / 1,4 kW Ignition electronic ignition system Fuel tank above the rear axle / 70 l Fuel supply electric supply pump Driven whells rear wheels Power transmission divided cardan shaft Frame desing self-supporting all-steel body Wheel suspension front triangle-wishbone / shock-absorber strut Wheel suspension rear multilink suspension, on demand with hydropneumatic level control Suspension front coil springs, torsion bar stabilizer Suspension rear coil springs, torsion bar type stabilizer Damper gas-pressure shock absorber struts / gas-pressure damper Steering ball-and-nut power steering Steering transm ratio 16,21:1 / 3,3 steering wheel turns Breaking system braking system Breaking system hydraulic dual-circuit braking system with vacuum-operated brake servo unit and antilock device; disc brakes front and rear Parking breake parking brake Parking breake mechanical (foot-operated), effective on rear wheels Diamatre brake discs front / rear: 284 / 258 mm Wheels sheet steel-disc wheels, on demand light-alloy disc wheels Wheels rims 6 1/2 J x 15 H 2; for sports suspension: 7 J x 15 H 2 Tyres 195/65 R 15 91 H; for sports suspension: 205/60 R 15 91 H |
