| Prosze o VIN !PILNE! https://forum.w114-115.org.pl/viewtopic.php?f=25&t=12587 |
Strona 1 z 2 |
| Autor: | Konri [ czw cze 02, 2005 11:23 pm ] |
| Tytuł: | Prosze o VIN !PILNE! |
prosze o rozkodowanie vin mb 190 z 89 roku WBD2010291F555882 . dzieki |
| Autor: | Samsung1 [ czw cze 02, 2005 11:32 pm ] |
jesteś pewien że z 89-tego? tutaj: http://www.vehicleidentificationnumber. ... -benz.html wyskakuje tak: VIN WBD2010291F555882 Year of Manufacture 2001 Chassis Code 201 Manufacturer Name BD Model 190 E 2.6 Restraint Systems Displacement Horsepower Fuel Diesel Production Plant Bremen Country of Manufacture Germany Production No. 555882 a tutaj: http://www.analogx.com/cgi-bin/cgivin.e ... mit=Decode tak: Vehicle Identification Number: Description Position Raw Data Decoded Data Region: 1 W Europe Country: 1-2 WB Germany Manufacturer: 2-3 BD Unknown Model Specific: 4-8 20102 Unknown Check Digit: 9 9 Invalid Year: 10 1 2001 Assembly Plant: 11 F F Serial Number: 12-17 555882 555882 a u kolegów z MB Russia tak; Datacard WBD2010291F555882 not found 1) VIN was incorrectly introduced in the form of demand; 2) VIN was incorrectly rewritten from the documents or from the body of automobile; 3) VIN was changed in the documents or on the body by criminals. S1 |
| Autor: | VALENTINE123 [ czw cze 02, 2005 11:40 pm ] |
VIN WDB2010291F555882 Model 190 E 2.6 nr nadwozia: 2010291F555882 nr silnika: 103942 10 011666 skrzynia: 717435 01 141495 ->manualna 5 biegów zamówienie: 0 7 287 90726 ->1987r Approx. year 1987 Lights BOSCH Wiper BOSCH Dealer authorities sales (287) tapicerka: cloth black (061) kolor:147 arctic white (T) (с 01.01.1985 по 31.12.1993) Options 211 automatic limited slip differential (ASD) (с 01.07.1984) rear axle with automatic limited slip differential (ASD) 228 auxiliary heater auxiliary heater (с 01.11.1974) auxiliary heater (only provision for installation in w 210) 240 outside temperature indicator (с 01.03.1982) 243 sports seats, front and rear (с 01.12.1986) 260 elimination of model designation on rear lid (с 01.05.1968) 261 elimination of model designation V12 (с 01.11.1973) 280 steering wheel (400 mm dia.) and gearshift lever in leather trim; on W202 390 mm dia. (с 01.05.1984) 412 electric sliding roof with tilting device (с 01.07.1983) 430 headrests in the rear (с 01.01.1977) 506 outside rear view mirror, left and right, heated (electrically adjustable on the right) (l.h.d.) (с 01.10.1983 по 31.03.1989) outside rear view mirror, right, convex, taxi export version 534 antenna, mechanically operated, without radio set (с 01.01.1963 по 30.11.1990) 543 sun visor with vanity mirror, illuminated, left and right (с 01.11.1978) 572 front seat, right, with seat height adjustment; l.h.d. (с 01.08.1975) 586 Behr air conditioner, and electric window lifters (front and rear doors) (с 01.04.1970) 591 heat-insulating glass, all-around, heated rear window pane, (single-sheet safety glass), Germany green heat-insulating glass all round, heated rear window, single pane safety glass - Germany (с 01.01.1972) 620 emission control system vehicles with catalyst technique (с 01.03.1985) 645 M+S tires (с 01.10.1963) 673 high-capacity battery (с 01.01.1964) 682 fire extinguisher (с 01.04.1970) 876 rear door contaCTS and lamp above rear window (с 01.07.1964 по 31.10.1993) 915 Unknown code |
| Autor: | Samsung1 [ czw cze 02, 2005 11:46 pm ] |
VALENTINE123 pisze: zamówienie: 0 7 287 90726 ->1987r
Approx. year 1987 czyli nie 89 S1 |
| Autor: | Konri [ czw cze 02, 2005 11:51 pm ] |
Jak moze byc model 190E 2,6 w dieslu? wyglada on tak:
martwi mnie to:
i co wy na to? Prosze o porady. (moge go kupic za 1300E) |
| Autor: | laudan [ czw cze 02, 2005 11:59 pm ] |
Samsung1 pisze: VALENTINE123 pisze: zamówienie: 0 7 287 90726 ->1987r Approx. year 1987 czyli nie 89 S1 87 to rok zlozenia zamowienia |
| Autor: | laudan [ pt cze 03, 2005 12:02 am ] |
Konri pisze: i co wy na to? Prosze o porady. (moge go kupic za 1300E)
W sumie cena jest pewnie odzwierciedleniem stanu, ale na fotkach nie jest zle, a troche rudego pod plastikami to znajdziesz prawie na kazdym (16 lat swoje robi). Fajnie wyposazenie, a choc cos z niego dziala ?
Jak dlugo to auto czeka na nabywce? |
| Autor: | Konri [ pt cze 03, 2005 12:05 am ] |
Wlasnie dziala wszystko. Nawet podswietlenie lusterek w oslonach przeciwslonechnych. |
| Autor: | VALENTINE123 [ pt cze 03, 2005 12:09 am ] |
Samsung1 pisze: czyli nie 89
S1 Co do daty produkcji ,to na podstawie tabliczki lakierowanej wychodzi mi 88' ,a na podstawie tabeli z numerami produkcyjnymi wychodzi przełom września-października 88'.Także podany 89' jest to data pierwszej rejestracji. |
| Autor: | Samsung1 [ pt cze 03, 2005 12:15 am ] |
Wszystko sie zgadza. Po prostu konri błędnie podał numer (czeski błąd) - przestawione trzy pierwsze znaki: Konri pisze: prosze o rozkodowanie vin mb 190 z 89 roku WBD 2010291F555882 . dzieki
nie zwróciłem na to uwagi S1 |
| Autor: | Konri [ pt cze 03, 2005 12:26 am ] |
Oczywiscie! Powinno byc 'WDB...' moj blad |
| Autor: | VALENTINE123 [ pt cze 03, 2005 12:44 am ] |
Wypas: 211-blokada dyferencjału(mostu) ,czyli ASD 228-webasto 240-wskaźnik temperatury zewnętrznej 243-sportowe siedzenia ,przód i tył 260-brak znaczka na tylniej klapie 261 ??? 280 kierownica 400mm i drzwidnia biegów w skórze 412-el. szyber dach 430-zagłówki z tyłu 506-el regulowane i podgrzewane lusterka 534 antena wysuwana ręcznie ,bez radia 543-lusterka w osłanach przeciwsłonecznych podświetlane 572-fotel kierowcy z regulacją wysokości 586-klima i el podnoszone szyby 591-szyby atermiczne 620-katalizator 645-opony zimowe 673-akumulator o podwyższonej pojemności 682 gaśnica 876 -dadatkowe załączanie lampek w tylnich dzwiach 915 -bak 70 litrów |
| Autor: | laudan [ pt cze 03, 2005 2:33 am ] |
Konri pisze: Wlasnie dziala wszystko. Nawet podswietlenie lusterek w oslonach przeciwslonechnych.
webasto tez? |
| Autor: | adi [ pt cze 03, 2005 7:37 am ] |
Widziałem co potrafi zrobić taka 2.6E .... dym z opon utrzymywał sie przez 40 minut a ślady 1,5 miesiąca
| Autor: | Grakoz [ pt cze 03, 2005 10:08 am ] |
adi pisze: dym z opon utrzymywał sie przez 40 minut a ślady 1,5 miesiąca
to nieźle ktoś się nudził |
