| [W187]Jaka waga całkowita? https://forum.w114-115.org.pl/viewtopic.php?f=24&t=47524 |
| Autor: | richie [ pn mar 15, 2010 12:59 pm ] |
| Tytuł: | [W187]Jaka waga całkowita? |
Hej, może ktoś z was dysponuję informacją ile waży dokładnie Mercedes 220B cabrio? Jest mi bardzo potrzebne a w necie nie mogę zlokalizować tej informacji. |
| Autor: | ZORTOX [ pn mar 15, 2010 1:03 pm ] |
nie wiem czy oto Ci chodzi..?? Type 220 S Cabriolet Name 220 S Cabriolet Name Mercedes-Benz type 220 S Cabriolet Short name 220 S Cabriolet Model W 180 II Production 07.56 - 10.59 Number produced 2.178 Comments concerning the production period Prices 21.500,00 DM Wheelbase 2700 mm Track rear/front 1430/1470 mm Length 4700 mm Width 1790 mm Height 1530 mm Smallest turning circle 10,7 m Chassis weight Max. total weight 1790 kg Max. front axle weight 840 kg Max. rear axle weight 950 kg Max. load 405 kg (with Hydrak: 390 kg) Max. trailer weight braked 1200 kg Max. trailer weight unbraked 740 kg Weight empty 1385 kg (with Hydrak: 1400 kg) According to guideline DIN 70020 (with fuel, spare wheel and tool equipment) Operating method four-stroke Otto Configuration front, parallel; upright Type M 180 III / 180.924 No. of cylinder/configuration 6 / in line Bore x stroke 80 x 72,8 mm Total displacement 2195 ccm (tax classification: 2171 ccm) Compression ratio 7,6; since 08.57: 8,7 Crankshaft bearing 4 Output 100 hp at 4800 /min; since 08.57: 106 hp at 5200 /min Maximum torque 16,5 mkg at 3500 /min; since 08.57: 17,5 mkg at 3500 /min No. of valves/configuration 1 intake, 1 exhaust / overhead Valve operation top camshaft Camshaft drive duplex roller-type chain Mixture formation 1 register-downdraught carburetter Solex 32 PAJTA Cooling water cooling / pump; 11,3 l water Lubrication pressure circulation lubrication / 6 l oil Electric system 12 V Battery 56 Ah / in the engine compartment Dynamo 160 W Starter motor electrical / 0,8 PS Ignition battery ignition Fuel tank in the rear / 64 l Fuel supply diaphragm pump Driven whells rear wheels Power transmission divided cardan shaft Frame desing floor assembly / self-supporting all-steel body Wheel suspension front double wishbone Wheel suspension rear single-joint swing axle Suspension front coil springs, torsion bar stabilizer Suspension rear coil springs Damper hydraulic telescopic damper Steering recirculating-ball steerg. Steering transm ratio 20,8:1 / 4 steering wheel turns Breaking system braking system Breaking system hydraulic, with vacuum-operated brake servo unit, effective on front- and rear wheels ; drum brakes front and rear Parking breake parking brake Parking breake mechanical, effective on rear wheels Diamatre brake drums front / rear: 230 mm Wheels sheet steel-disc wheels Wheels rims drop centre rim 5 K x 13 Tyres 6,70-13 Sport Skrzynie biegów tego modelu (gearbox and performance): "Ponton"-Coup�s and~-Convertibles, types~220 S and 220 SE (W 180, W 128) Mercedes-Benz type 220 S Cabriolet Gearbox 4-speed gear shift Availability Series Shifting Gear shift Clutch Single-plate dry clutch Type of gearbox Pinion change gear Synchromesh gears I - IV Gear transmission I. 3,52; II. 2,32; III. 1,52; IV. 1,0; R. 3,29 Differential ratio 4,10 Maximum speed 160 km/h Accelerations 17 s Comments Acceleration with shifting through from 0 - 100 km/h; loaded with 2 persons Fuel consumption 10,7 l acc. to guideline DIN 70030, ascertained at 3/4 of max. speed, maximal 110 km/h, unter Zuschlag von 10 % "Ponton"-Coup�s and~-Convertibles, types~220 S and 220 SE (W 180, W 128) Mercedes-Benz type 220 S Cabriolet Gearbox 4-speed gear shift Availability by request (from 08.57) Shifting Gear shift Clutch hydr.-aut. clutch "Hydrak" Type of gearbox Pinion change gear Synchromesh gears I - IV Gear transmission I. 3,52; II. 2,32; III. 1,52; IV. 1,0; R. 3,29 Differential ratio 4,10 Maximum speed 160 km/h Accelerations 17 s Comments Acceleration with shifting through from 0 - 100 km/h; loaded with 2 persons Fuel consumption 10,9 l acc. to guideline DIN 70030, ascertained at 3/4 of max. speed, maximal 110 km/h, unter Zuschlag von 10 % |
| Autor: | richie [ pn mar 15, 2010 1:16 pm ] |
niestety ty podałeś dane następnego modelu, mi chodzi o 220B cabrio z początku lat 50-tych. Generalnie mam trochę opisów ale nigdzie nie mam wagi;( |
| Autor: | Stomek [ pn mar 15, 2010 1:18 pm ] |
ZORTOX pisze: nie wiem czy oto Ci chodzi..??
Model W 180 II Production 07.56 - 10.59 Chodzi o Cabrio (A czy B??) W 187, czyli jakby obecna s-klasa w cabrio produkowana w latach 51-55. Masa wlsna kabrioleta (A i B) to 1440kg (wedlug Wikipedia) PS Ktos tu sie chyba czai na auto moich marzen (cabrio A) |
| Autor: | richie [ pn mar 15, 2010 1:21 pm ] |
chodzi o B niestety;( |
| Autor: | Stomek [ pn mar 15, 2010 1:25 pm ] |
Juz sie czailem kiedys na tego w mazowieckim, ale stwierdzilem ze jak ma byc A to A i trzeba pocierpiec jeszcze jakis czas, zeby w koncu miec tego wymarzonego
| Autor: | richie [ pn mar 15, 2010 1:29 pm ] |
ten z Mińska Mazowieckiego to niewykończony projekt i już skundlony, brakowało trochę gratów a część już po amerykańsku przerobione. Ja czaję się na w pełni oryginalny 220B jeszcze nie ruszany, ale zobaczmy co z tego bedzie |
| Autor: | Stomek [ pn mar 15, 2010 1:35 pm ] |
richie pisze: .... jeszcze nie ruszany, ale zobaczmy co z tego bedzie
I na takiego tez ja sie kiedys przyczaje , ale A.
| Autor: | richie [ pn mar 15, 2010 1:38 pm ] |
coraz mniej tych nie ruszanych a coraz wiecej powyzej 100k. eur po renowcji w kinle itp. |
| Autor: | Stomek [ pn mar 15, 2010 1:41 pm ] |
Jakos da sie rade, najwazniejsze ze wydatek jest/bedzie zaakceptowany przez szefowa |
| Autor: | richie [ pn mar 15, 2010 1:59 pm ] |
ok znalazłem takie info: dry weight: 1440kg. loaded weight: 1785kg. no i o co w tym chodzi? |
| Autor: | Stomek [ pn mar 15, 2010 2:54 pm ] |
richie pisze: ok znalazłem takie info:
dry weight: 1440kg. loaded weight: 1785kg. no i o co w tym chodzi? Wrzucilem mase wlasna juz w pierwszym swoim poscie- 1440kg. Dopuszczalna masa calkowita to 1785kg |
| Autor: | richie [ pn mar 15, 2010 3:22 pm ] |
no to kazcko bo laweta którą mam wypożyczyć ma ładowność 1540kg:) |
| Autor: | Stomek [ pn mar 15, 2010 3:33 pm ] |
Pochwal sie nabytkiem, jak przytaszczysz |
