| [W123ce] Prośba o rozkodowanie VIN-u https://forum.w114-115.org.pl/viewtopic.php?f=24&t=25501 |
| Autor: | jugo500 [ wt kwie 24, 2007 11:15 am ] |
| Tytuł: | [W123ce] Prośba o rozkodowanie VIN-u |
szukałem szablonu ale chyba zostal odwieszony i gdzieś mi go wcieło . 12305322019065 |
| Autor: | Tomek [ wt kwie 24, 2007 11:28 am ] |
VIN WDB12305322019065 Model 280 CE Chassis 12305322019065 Engine 110984 22 074790 Transmission 02 126451 Order 0 0 537 61457 Approx. year 1980 Dealer Great Britain (537) Interior Unknown code (935) Paint 940 marine blue (T) (с 01.01.1979 по 31.12.1981) Options 286 luggage nets on front seat backrests (с 01.01.1962) 320 additional plate and rear seat bench stop for great britain (с 01.03.1967 по 31.07.1980) 339 front seat, left lower (с 01.03.1967 по 29.02.1996) 340 front seat, right, lower (с 01.03.1967 по 28.02.1986) 410 electric sliding roof (с 01.03.1965 по 29.02.1988) 420 automatic transmission, floor shift (с 01.01.1963) 432 headrests in the rear and elimination of front and rear safety belts (с 01.01.1977 по 28.02.1986) headrests in the rear, elimination of automatic (self-reeling) safety belts 440 tempomat (cruise control) (с 01.09.1975) 467 central locking system and instruments with english lettering (с 01.04.1970 по 31.10.1993) 524 paintcoat preservation (с 01.01.1964) 570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970) front folding armrest w202 - housing at front with armrest 583 electric window lifters (front doors) (с 01.04.1970) 593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972) 613 lamp unit, asymmetrical, l.h. traffic (с 01.02.1963) 656 Michelin tires (с 01.08.1965 по 31.10.1989) 666 10 liters of fuel and mode of packing VE II (с 01.12.1965 по 31.08.1986) |
| Autor: | chymon [ wt kwie 24, 2007 11:28 am ] |
Witam kolegę, rozkmiliwszy - wklejam
VIN WDB12305322019065 Model 280 CE (...) już nie będę dalej zaśmiecał
Dane ze strony: http://www.mbclub.ru/mb/vin/?lng=eng A tu masz mniej interaktywny klucz: http://www.w114-115.org.pl/jomla/content/view/105/77/ Przykłady kolorów i wzorów tapicerek: http://www.astralsilber.de/ Pozdrawiam
| Autor: | jugo500 [ wt kwie 24, 2007 11:41 am ] |
Dzięki Tomek . tak sie właśnie zastanawiam nad tym coupe http://cgi.ebay.co.uk/1980-MERCEDES-280 ... dZViewItem bo transport to juz nie problem a pojezdziło by sie chymon właśnie tego klucza szukałem |
| Autor: | chymon [ wt kwie 24, 2007 11:46 am ] |
Dokleisz PL z gwiazdkami na tablicę rejestracyjną i śmigasz jako rodowity mieszkaniec okolic Gdańska - taki Pruszczanin np
| Autor: | SKOWRON [ wt kwie 24, 2007 12:22 pm ] |
z zewnątrz jak bliźniaczka mojej
| Autor: | buckswizz [ wt kwie 24, 2007 7:01 pm ] |
oz kurde to jeszcze taniej niz mój,i na zdjeciach ladniej wyglada... |
| Autor: | kielbik [ śr kwie 25, 2007 12:31 am ] |
jugo500 pisze: 12305322019065 jugo500 pisze: Dzięki Tomek . tak sie właśnie zastanawiam nad tym coupe http://cgi.ebay.co.uk/1980-MERCEDES-280 ... dZViewItem Widze, ze robi sie ruch w angolach bo transport to juz nie problem a pojezdziło by sie SKOWRON pisze: tylko w środku trochę lepiej buckswizz pisze: na zdjeciach ladniej wyglada... Panowie, czytac, czytac...Cytuj: nterior is bad and body has rust Cytuj: only problem when starting is it will start out of park Cytuj: will need to be trailerd away Ale swoja droga samochody w kiepskim stanie sa w Anglii naprawde tanie, w Niemczech nawet kupa zlomu wyciagnieta ze stawu sprzeda sie na eBayu za min 500-800 €
| Autor: | el_diablo [ śr kwie 25, 2007 12:07 pm ] |
Tomek pisze: 432 headrests in the rear and elimination of front and rear safety belts (с 01.01.1977 по 28.02.1986)
headrests in the rear, elimination of automatic (self-reeling) safety belts Ciekawa opcja... ktoś fantazję miał. Ciekawe czy to też było za dopłatą... |
| Autor: | jugo500 [ śr kwie 25, 2007 12:25 pm ] |
kielbik masz racje . od jakiegos czasu na ebay.de złomy chodza za więcej niz na złomie :/ nie wiem czy aurat kupie tego niebieskiego ,czy dam troszkę więcej i kupie w lepszym stanie , ale UK jest bardzo obiecującym rynkiem natomiast jeżeli chodzi o Niemcy to juz tylko mega szczęście ci pomoże |
| Autor: | buckswizz [ śr kwie 25, 2007 2:40 pm ] |
w sumie w Anglii klasyki w dobrym stanie tez sa drogie,ale jesli cos jest w takim stanie jak w/w to da sie cos znalezc w miare tanio-choc to tanio jest tez bardzo umowne... |
| Autor: | kielbik [ śr kwie 25, 2007 5:40 pm ] |
buckswizz pisze: choc to tanio jest tez bardzo umowne... no nie przesadzaj: 122 £, czyli niecale 200 € - sprzedasz felgi, zderzaki, pare drobiazgow i juz masz dwa razy tyle (nawet jak uwzglednisz koszty transportu). W Niemczech nie byloby szans na taki zakup, jak piec lat tu siedze jeszcze sie taka okazja nie zdarzyla.
| Autor: | buckswizz [ śr kwie 25, 2007 6:40 pm ] |
pewnie masz racje... p.s doszly zdjecia? |
