| POMOCY W ROZKODOWANIU VIN-u https://forum.w114-115.org.pl/viewtopic.php?f=24&t=25255 |
| Autor: | wisnia [ czw kwie 12, 2007 10:15 pm ] |
| Tytuł: | POMOCY W ROZKODOWANIU VIN-u |
Witam! Proszę o pomoc w rozkodowaniu kodu VIN WBD123 130 102 416 61 oraz jak rozkodować doka |
| Autor: | johnye300 [ czw kwie 12, 2007 10:23 pm ] |
VIN WDB12313010241661 Model 300 D Chassis 12313010241661 Engine 617912 10 142338 Transmission 00 883841 Order 0 1 531 13860 Approx. year 1981 Lights HELLA Cab 10711 Dealer France, Monaco (531) Interior Unknown code (034) Paint 479 walnut brown (T) (с 01.01.1979 по 31.12.1981) Options 286 luggage nets on front seat backrests (с 01.01.1962) 466 central locking system (с 01.04.1970 по 31.10.1993) 533 interference suppression without radio set (с 01.01.1967 по 29.02.1984) 542 lockable glove compartment (с 01.02.1963 по 29.02.1986) 570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970) front folding armrest w202 - housing at front with armrest 583 electric window lifters (front doors) (с 01.04.1970) 593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972) 610 headlamps and fog lamps and additional bright light with amber lenses (с 01.11.1965 по 31.03.1994) 629 version for France (с 01.04.1964 по 29.02.1988) 630 ECE warning triangle (с 01.08.1980) 665 876 rear door contaCTS and lamp above rear window (с 01.07.1964 по 31.10.1993) CHYBA AUTO KOLEGI BAREGO BYLO W TAKIM KOLORZE. |
| Autor: | wisnia [ czw kwie 12, 2007 10:42 pm ] |
a może ktos wie co na polski onaczają te kody miedzy innymi 286 533 542 570 593 630 <br>Dodano po 11 minutach.:<br> johnye300 pisze: Dealer France, Monaco (531)
TO MNIE NAJBARDZIEJ ZADZWIA |
| Autor: | Janfocus [ czw kwie 12, 2007 11:44 pm ] |
wisnia pisze: Dealer France, Monaco (531)
TO MNIE NAJBARDZIEJ ZADZWIA Oznacza to samo co kod 629 -czyli auto robione na Francję... Pewnie masz żółte przeciw mgielne, albo raczej takie powinny być. 286 wygląda na siatki (schowek) z tyłu oparć przednich foteli, 533 automatyczna antena ale bez radia (takie mam przeczucie) bo słownik techniczny mam nie zainstalowany 570 przedni podłokietnik 593 szyby atermiczne -zielonkawe 630 trójkąt ostrzegawczy |
| Autor: | daro5555 [ pt kwie 13, 2007 2:28 pm ] |
wisnia pisze: [W121] POMOCY W ROZKODOWANIU VIN-u To VIN W123 a nie W121 |
| Autor: | wisnia [ pt kwie 13, 2007 11:57 pm ] |
te lampy powinny być hella a jak na razie znalazłem tylko boschoskie z żółtym przeciwmgielnym cos takiego--->_ czy to są te które powinieniem mieć..?http://www.allegro.pl/item184828781_lampy_bosch_zolty_halogen_mercedes_w123_rarytas.html |
| Autor: | Janfocus [ sob kwie 14, 2007 12:59 am ] |
z '81 w dieslu to okrągłe |
| Autor: | kielbik [ ndz kwie 15, 2007 2:36 am ] |
ty powinienes miec takie reflektory: http://www.allegro.pl/item178948840_ref ... s_123.html Oprocz tego mozna przerobic zwykly reflektor montujac w nim te zolta przeslone miedzy lustrem a szklem. Powinno byc do dostania w ASO lub w firmie Hella. |
| Autor: | wisnia [ ndz kwie 15, 2007 10:26 am ] |
dzieki za pomoc <br>Dodano po 1 minutach.:<br> może i można tak zrobic ale wtedy musiał bym mieć okragłe lamy a ja mam prostokątne więc lipa <br>Dodano po 26 minutach.:<br> może ktoswie jak sprawdzzić jakie dokądanie powinny być te lamy czy okrągłe z żółtym przeciwmgielnym czy prostokątne ..? |
| Autor: | MajsterGarage [ ndz kwie 15, 2007 1:23 pm ] |
wisnia pisze: może ktoswie jak sprawdzzić jakie dokądanie powinny być te lamy czy okrągłe z żółtym przeciwmgielnym czy prostokątne
Kwadratowe lampy weszły razem z III seria, czyli w 1982 roku, wczescniej byly montowane tylko do 280 i 280E. |
| Autor: | wisnia [ pn kwie 23, 2007 9:22 pm ] |
kielbik pisze: Oprocz tego mozna przerobic zwykly reflektor montujac w nim te zolta przeslone miedzy lustrem a szklem
Wie może ktos gdzie i jak szukać ...? |
