| [W116] BZDURY pisza w internecie. https://forum.w114-115.org.pl/viewtopic.php?f=24&t=18796 |
| Autor: | jakub_gozdzik [ pn maja 15, 2006 12:42 pm ] |
| Tytuł: | [W116] BZDURY pisza w internecie. |
Dzis ogladalem jedna ze stron o Mercedesie W 116 i co przeczytalem
Rece opadaja
| Autor: | wojz [ pn maja 15, 2006 1:00 pm ] |
znajoma jakaś taka mi się wydaje |
| Autor: | bary123ce [ pn maja 15, 2006 1:03 pm ] |
a w baku robili dziurę??
| Autor: | lysy2 [ pn maja 15, 2006 2:08 pm ] |
stronka znajoma
Maćku co Ty ludziom za kity wciskasz?
| Autor: | MacKuz [ pn maja 15, 2006 3:30 pm ] |
Chmmm nie jestem w 100% autorem tego artykułu ale faktem jest że trzeba to zweryfikować ( no i świadomość była duzo mniejsza w momencie pisania artykułu) Artykuł przetłumaczył i napisał kolega WPK ja go tylko potem doszlifowałem. Treść była w wiekszości pobrana z multimedialnej encyklopedii mercedesa. podstawowy dokument źródłowy: Cytuj: In September 1972 a totally new car generation of the upper class was presented to the public. For the first time the name ,Mercedes-Benz S-class" was officially used. It replaced the type range 108/109 and at that time consisted of types 280_S, 280_SE and 350_SE. Six months later the S-class limousine was also available with a larger displacement capacity in the 4,5_ltr.-V8-engine, parallel to the 450_SL and the 450_SLC. At the same time type 450_SEL was issued with a 100 mm longer wheel base. As with its predecessors the driver thus benefited from the newly gained leg room. Since November 1973 the prolonged version was also available as 350_SEL, since April_1974 finally also as 280_SEL. A remarkable technical novelty in the limousines of type range 116 was the twin control arm front wheel suspension with zero steering offset_ and brake dive support. It improved the handling characteristics of the car considerably. The rear wheel suspension corresponded for the most part to the construction which had proved itself for years in the ,strike-eight"-type and was also used in the 350_SL. In terms of passive safety the S-class also outlined the latest technological development. The many construction details realised in the 350_SL for the first time and for safety reasons now, of course, were transferred as a whole to the S-class limousines. Thus the fuel tank was not located in the rear end of the car anymore, but above the rear axle and thus protected against collision. Inside a heavily padded dashboard, deformable or conceiling switches and controls as well as a new four-spoke security wheel with impact absorber and broad impact cushion provided for utmost crash protection. Important improvements in comparison to the preceding type range was the even more stable security passenger cell with stiffened roof-frame structure, high-strength roof and door pillars as well as reinforced doors. The energy absorption of the front and rear deformation zone in the front and rear end was significantly increased by a controlled deformation capacity. Newly developed cowl panels at the A-pillars, serving as water-shield gutters, guaranteed good visibility in rain and kept the side windows clean in bad weather. Further security details were wide wraparound direction indicators, well visible also from the side. In addition, broad rear lamps with ribbed surface profile proved to be very insusceptible to dirt. In May 1975 type 450_SEL was presented as the new top model of the type range and as the legitimate successor to 300_SEL_6.3. The powerful 6.9_ltr.-V8-motor, developed from the 6.3_ltr. -aggregate, achieved 286_PS and a maximal torque of 56_mkg. For the first time in a Mercedes-Benz car a hydropneumatic suspension with level control system guaranteed highest driving comfort. Further optional equipment belonging to the production delivery of the top model included central locking system, air-conditioning and headlamp washer system. As its direct predecessor, the 450_SEL_9 was an immediate and full success. Even though it was more than twice as expensive than the 350_SE, 7.380 cars were built within its production time of four years and six months. Between November 1975 and February 1976 the fuel injection system of the 2, 8_ltr.-, 3,5_ltr.- and 4,5_ltr.-injection engines was changed in order to correspond to the now higher exhaust-emission standards in most European countries. The electronically controlled Bosch ,D-Jetronic" was replaced by the newly developed mechanically controlled Bosch "K=Jetronic". In all three cases the conversion was connected to slight power reductions. In the 2,8_ltr.- engine as well as in the 3,5_ltr.- engine the compression was lowered at the same time. In order to facilitate maintenance both V8=engines were equipped with a breakless transistor ignition and a hydraulic valve-clearance compensation. Parallel to the 2,8_ltr.- injection engine the compression was also lowered in the carburettor engine. Here, too, this led to a reduced potential of performance. Two years later, since April 1978, the original performance of all three models with injection engine was reached again. With the 2,8_ltr.-injection engine - in contrast to the carburettor engine - the compression was increased to its old value. With the two V8=models the former performance was basically achieved by changing the exhaust-emission system. In May_1978 the model range of the series 116 was once more extended. The new member of the family, type 300_SD, gained as much attention as the 450_SEL_6.9 three years before. The new S-class model, however, was at the other end of the performance scale and - for the first time in the history of this vehicle category - was driven by a Diesel engine. The 3,0_ltr.-5_ cylinder aggregate which had proven so well in the types 240_D_3.0 and. 300_D was now provided with a turbocharger and thus with a new task. This made it possible to increase the performance to 115_PS. The development of this unusual S-class variant, which was exclusively available in the USA and Canada, had been started with the goal to fulfil the lower consumption figures newly introduced by the US-government. The important figure was the so-called ,fleet consumption", an invention of the Carter-administration, which designated the average consumption of all car-models made available by a manufacturer. With an extended offer of traditionally economical Diesel models the fleet consumption could be lowered under the legal limit. A technical innovation of trend-setting importance was available since autumn 1978, world exclusively in the S-class-limousines of the type range 116: the antilock system (ALS) which had been developed together with the Robert-Bosch_GmbH. It guarantees the unrestricted controllability of the vehicle even when slamming on the brakes, thus contributing considerably to active safety. Today it is almost self-evident and also available in small cars. In those days, however, the market introduction of the ALS was a real sensation. Safety of a different kind was offered by the extra-safe versions of the type range 116. Based on the experience gained by the development of the specially safe 280_SEL3.5, the protection technology could be further improved. Altogether 292 cars were produced from the eight-cylinder models 350_SE, 350_SEL, 450_SE and 450_SEL and delivered to selected clients, among them many state institutions in Europe and overseas. In September 1979 types of the series 126 were represented at the Frankfurt motor show IAA. They were the successors of the first S-class type range. The production of the type range 116, however, was not finished yet. It stopped only between April and September 1980, depending on the type. The last car of a total of 473.035 built units of this model range that passed the final-assembly inspection at the plant in Sindelfingen was a 300_SD. tutaj wersja po niemiecku Cytuj: Eine völlig neu entwickelte Fahrzeuggeneration der Oberklasse wurde im September 1972 der Öffentlichkeit präsentiert. Die erstmals offiziell so genannte "Mercedes-Benz S=Klasse"_- interne Bezeichnung W_116_- löste die Baureihe 108/109 ab und umfabte zunächst die Typen 280_S, 280_SE und 350_SE. Ein halbes Jahr später wurde die S=Klasse Limousine, parallel zum 450_SL und 450_SLC, auch mit dem hubraumstärkeren 4,5_ltr.-V8-Motor angeboten. Zum selben Zeitpunkt erschien der Typ 450_SEL mit einem um 100 mm verlängerten Radstand; wie bei seinen Vorgängermodellen, kam der Raumgewinn der Beinfreiheit im Fond zugute. Die verlängerte Version war ab November 1973 auch als 350_SEL, ab April_1974 schlieblich auch als 280_SEL erhältlich. Eine bemerkenswerte technische Neuerung, die in Serie erstmals bei den Limousinen der Baureihe 116 realisiert wurde, war die beim C_111 erprobte Doppelquerlenker-Vorderradaufhängung mit Lenkrollradius_0 und Bremsnick-Abstutzung; sie ermöglichte eine weitere Verbesserung der Fahreigenschaften. Die Hinterradaufhängung entsprach im wesentlichen der Konstruktion, die sich in den "Strich-Acht"-Typen mittlerweile seit Jahren bewährt hatte und auberdem im 350_SL verwendet wurde. Auch hinsichtlich der Passiven Sicherheit markierte die S=Klasse den Stand der Technik: Die Vielfalt der beim 350_SL erstmals realisierten sicherheitsrelevanten Konstruktionsdetails kam selbstverständlich ohne Einschränkung auch den S=Klasse-Limousinen zugute: So befand sich der Kraftstofftank nun nicht mehr im Wagenheck, sondern war kollisionsgeschutzt uber der Hinterachse eingebaut; im Innenraum sorgten das stark gepolsterte Armaturenbrett, deformierbare oder versenkt angeordnete Schalter und Hebel sowie ein Vierspeichen-Sicherheitslenkrad mit Pralltopf und breiter Polsterplatte fur gröbtmöglichen Aufprallschutz. Wichtigste Verbesserung im Vergleich zur Vorgänger-Baureihe war die noch stabilere Sicherheits-Fahrgastzelle mit versteifter Dachrahmen-Struktur, hochfesten Dachpfosten und Tursäulen sowie verstärkten Turen. Die Energieabsorption der vorderen und hinteren Knautschzone konnte durch kontrollierte Deformationsfähigkeit von Vorbau und Heckbereich deutlich erhöht werden. Gute Sichtverhältnisse garantierten spezielle Windleitprofile an den A=Säulen, die bei Regen als Schmutzwasserrinnen dienten und die Seitenscheiben auch bei ungunstiger Witterung sauber hielten. Weitere sicherheitsrelevante Details waren die weit herumgezogenen, auch seitlich gut sichtbaren Blinker sowie grobflächige Heckleuchten, die dank ihres gerippten Oberflächenprofils weitgehende Unempfindlichkeit gegen Verschmutzung zeigten. Im Mai 1975 wurde der Typ 450_SEL_6.9 als neues Spitzenmodell der Baureihe und legitimer Nachfolger des 300_SEL_6.3 präsentiert; der leistungsstarke 6,9_ltr.-V8-Motor, entwickelt aus dem bewährten 6.3_ltr.-Aggregat, erreichte eine Leistung von 286_PS und ein maximales Drehmoment von 56_mkg. Höchsten Fahrkomfort gewährleistete die erstmals bei einem Mercedes-Benz Pkw eingesetzte hydropneumatische Federung mit Niveauregulierung. Weitere Sonderausstattungen, die zum serienmäbigen Lieferumfang des Topmodells gehörten, waren Zentralverriegelung, Klimaanlage und Scheinwerfer-Waschanlage. Wie sein direkter Vorgänger, konnte auch der 450_SEL_6.9 auf Anhieb als voller Erfolg verbucht werden; obwohl er mehr als doppelt so teuer war wie ein 350_SE, wurden in der viereinhalbjährigen Produktionszeit 7.380 Exemplare gebaut. Zwischen November 1975 und Februar 1976 wurde die Kraftstoff-Einspritzanlage der 2,8_ltr.-, 3,5_ltr.- und 4,5_ltr.-Einspritz-Motoren umgestellt, um den mittlerweile auch in den meisten europäischen Ländern verschärften Emissionsgrenzwerten besser entsprechen zu können. Von der elektronisch geregelten Bosch "D=Jetronic" wechselte man zur neu entwickelten, mechanisch geregelten Bosch "K=Jetronic". Die Umstellung war in allen drei Fällen mit geringfugigen Leistungseinbuben verbunden; beim 2,8_ltr.- und beim 3,5_ltr.-Motor hatte man gleichzeitig die Verdichtung etwas reduziert. Zur Wartungserleichterung erhielten die beiden V8=Motoren im Rahmen dieser Mabnahmen eine kontaktlose Transistorzundung und hydraulischen Ventilspiel-Ausgleich. Parallel zum 2,8_ltr.-Einspritzer wurde beim Vergasermotor ebenfalls die Verdichtung gesenkt, was auch in diesem Fall ein reduziertes Leistungspotential zur Folge hatte. Gut zwei Jahre später, ab April 1978, stand die ursprungliche Leistung bei den drei Modellen mit Einspritzmotor wieder zur Verfugung. Beim 2,8_ltr.-Einspritzer hatte man, im Gegensatz zur Vergaserversion, die Verdichtung auf den alten Wert angehoben; bei den beiden V8=Modellen wurde das fruhere Leistungspotential im wesentlichen durch Änderungen an der Auspuffanlage erreicht. Im Mai_1978 wurde die Modellpalette der Baureihe 116 noch einmal erweitert. Als neues Mitglied der Typenfamilie erregte der Typ 300_SD in Fachkreisen ebensoviel Aufmerksamkeit wie drei Jahre zuvor der 450_SEL_6.9, war aber am entgegengesetzten Ende der Leistungsskala angesiedelt. Angetrieben wurde das neue S=Klasse-Modell, erstmals in der Geschichte dieser Fahrzeug-Kategorie, von einem Dieselmotor. Das 3,0_ltr.-5_Zyl.-Aggregat, das sich in den Typen 240_D_3.0 bzw. 300_D bestens bewährt hatte, war fur seine neue Aufgabe mit einem Turbolader versehen worden, der eine Leistungssteigerung auf 115_PS ermöglichte. Die Entwicklung dieser ungewöhnlichen S=Klasse-Variante, die ausschlieblich in den USA und Kanada angeboten wurde, hatte man mit der Zielsetzung begonnen, die von der US-Regierung neu eingefuhrten Verbrauchsgrenzwerte zu erfullen. Mabgebliche Gröbe war dabei der sogenannte "Flottenverbrauch", eine Erfindung der Carter-Administration, die den Durchschnittsverbrauch aller angebotenen Pkw-Modelle eines Herstellers bezeichnete. Mit einem erweiterten Angebot an traditionell sparsamen Dieselmodellen konnte der Flottenverbrauch unter das gesetzliche Limit gesenkt werden. Eine technische Innovation von richtungsweisender Bedeutung wurde ab Herbst 1978 weltexklusiv in den S=Klasse-Limousinen der Baureihe 116 angeboten: das gemeinsam mit der Robert-Bosch_GmbH entwickelte Anti-Blockier-System (ABS), das die uneingeschränkte Lenkfähigkeit des Fahrzeugs auch bei einer Vollbremsung garantiert und damit einen wesentlichen Beitrag zur Aktiven Sicherheit leistet. Nachfolger der ersten S-Klasse-Modellreihe wurden die im September 1979 auf der Frankfurter IAA präsentierten Typen der Baureihe 126. Die Produktion der Baureihe 116 war damit aber noch nicht beendet, sondern lief, je nach Typ, erst zwischen April und September 1980 aus. Als letztes von insgesamt 473.035 gebauten Exemplaren dieser Modellreihe passierte ein Typ 300_SD die Endabnahme im Werk Sindelfingen.
| Autor: | MercBeginner [ pn maja 15, 2006 8:33 pm ] |
bary123ce pisze: a w baku robili dziurę??
![]() Jeden energinczy ruch i narta siedzi. Dopóki się jej nie wyjmie to nie będzie tak bardzo wyciekać nawet |
| Autor: | bary123ce [ wt maja 16, 2006 1:22 pm ] |
buehehehe! |
| Autor: | MacKuz [ wt maja 16, 2006 2:42 pm ] |
Tekst został zmodyfikowany |
| Autor: | kocur [ wt maja 16, 2006 3:55 pm ] |
Nie wiem jak tam z niemieckim, ale w angielskim ani słowa o nartach... |
