Dzisiaj jest pt lis 13, 2026 10:59 am
Post: sob lut 10, 2007 1:50 pm
Witam Wszystkich!
Czy Ktoś mogły przetłumaczyć na polski poniższe kody:
228 auxiliary heater
auxiliary heater (с 01.11.1974)
auxiliary heater (only provision for installation in w 210)
430 headrests in the rear (с 01.01.1977)
504 outside rear view mirror, right, electrically adjustable
(с 01.11.1978 по 29.02.1986)
outside rear view mirror, right, electrically adjustable (l.h.d.)
taxi version, f.r.g, and outside rear view mirror on the right
532 automatic antenna without radio set (с 01.01.1963)
570 folding armrest front w202/210 stowage box front with armrest
(с 01.04.1970)
front folding armrest w202 - housing at front with armrest
600headlamp wiper/washer (с 01.08.1971)
682 fire extinguisher (с 01.04.1970)
812 rear-mounted loudspeaker (с 01.11.1974)
oraz to:
Dealer: authorities sales / company employee (12 months) (283)
Interior: Unknown code (031)
591 heat-insulating glass, all-around, heated rear window pane,
(single-sheet safety glass), Germany
reen heat-insulating glass all round, heated rear window,
single pane safety glass - Germany (с 01.01.1972)
502 outside rear view mirror, on the right
(с 01.01.1963 по 31.03.1983)
536 interference suppression without radio set and mechanically
operated antenna (с 01.01.1970 по 31.07.1997)
Z góry dziekuje ;)
S123 300TD
Post: sob lut 10, 2007 1:59 pm
MajsterGarage pisze:
Witam Wszystkich!
228 auxiliary heater webasto
430 headrests in the rear (с 01.01.1977)zagłówki z tyłu
(с 01.11.1978 по 29.02.1986)prawe lusterko el. regulowane
532 automatic antenna without radio set (с 01.01.1963)automatyczna antena ,bez radia
570 folding armrest front w202/210 stowage box front with armrest podłokietnik z przodu
(с 01.04.1970)
600headlamp wiper/washer (с 01.08.1971)wycieraczka reflektorów
682 fire extinguisher (с 01.04.1970)gaśnica
812 rear-mounted loudspeaker (с 01.11.1974) głośniki tylne
oraz to:
Dealer: authorities sales / company employee (12 months) (283) auto dla pracownika koncernu
single pane safety glass - Germany (с 01.01.1972)szyby atermiczne,podgrzewana tylna szyba
502 outside rear view mirror, on the right prawe lusterko
operated antenna (с 01.01.1970 по 31.07.1997)filtr przeciwzakłóceniowy,bez radia ,recznie wysuwana antena
Z góry dziekuje ;)
124 E220 coupe 96'FOTO
MB artykuły prasowe cz1
MB artykuły prasowe cz2
Post: sob lut 10, 2007 2:37 pm
A ten kod od tapicerki?
S123 300TD
Post: sob lut 10, 2007 2:51 pm
tapicerka czarna tkanina
Post: ndz lut 11, 2007 12:53 am
link z przykładem tapicerki ktora pochodzi z drugiej serii:
http://www.astralsilber.de/polsterungen/031.jpg
MERCEDES W210 290TD 98rok
MERCEDES W123 240D 81/83rok
MERCEDES W123 240D 81rok(dawca na cześci)
VOLKSWAGEN PASSAT B3 1.9TD 93 rok
http://www.forum.vw-passat.pl/showthread.php?t=20165
http://marcin-liput.fotosik.pl/albumy/255649.html
