| JAKI MOST DO W 115 280? https://forum.w114-115.org.pl/viewtopic.php?f=22&t=13737 |
| Autor: | heniekx [ śr sie 17, 2005 12:45 pm ] |
| Tytuł: | JAKI MOST DO W 115 280? |
POMOCY !!!! JAKIE PRZELOZENIE MIAL MOST DO SILNIKA 280 W 115? MAM 115 200 D ALE CHCE ZMIENIC SILNIK NA 280 TYLKO NIE WIEM JAKIE OZNACZENIA MIAL MOST TYLNY OD TEGO SILNIKA A CO ZA TYM IDZIE JAKIE MIAL PRZELOZENIE. BEDE WDZIECZNY ZA POMOC ORAZ ZA EWENTUALNE NAMIARY GDZIE TAKI ZNAJDE. POZDRAWIAM. |
| Autor: | MacKuz [ śr sie 17, 2005 12:47 pm ] |
Wszystko zależy od skrzyni biegów: Gearbox 4-speed gear shift Availability Series Shifting steering wheels or feed control Clutch Single-plate dry clutch Type of gearbox Pinion change gear Synchromesh gears I - IV Gear transmission I. 3,90; II. 2,30; III. 1,41; IV. 1,0; R. 3,66 Differential ratio 3,69 Maximum speed 200 km/h Accelerations 9,9 s Comments Acceleration with shifting through from 0 - 100 km/h; loaded with 2 persons Fuel consumption 12,5 l acc. to guideline DIN 70030, ascertained at 3/4 of max. speed, maximal 110 km/h, unter Zuschlag von 10 % * * * Gearbox 5-speed gear shift Availability by request Shifting Feed control Clutch Single-plate dry clutch Type of gearbox Pinion change gear Synchromesh gears I - V Gear transmission I. 3,96; II. 2,34; III. 1,43; IV. 1,0; V. 0.87; R. 3,72 Differential ratio 3,92 Maximum speed 200 km/h Accelerations 9,9 s Comments Acceleration with shifting through from 0 - 100 km/h; loaded with 2 persons Fuel consumption 12,5 l acc. to guideline DIN 70030, ascertained at 3/4 of max. speed, maximal 110 km/h, unter Zuschlag von 10 % * * * Gearbox 4-speed autom. gear shift Availability by request Shifting Switch lever at steering wheel or in car center Clutch hydr. torque converter in the autom. gear Type of gearbox Planet gear Synchromesh gears ========== Gear transmission I. 3,98; II. 2,39; III. 1,46; IV. 1,0; R. 5,47 Differential ratio 3,69 Maximum speed 195 km/h Accelerations 10,8 s Comments Acceleration with shifting through from 0 - 100 km/h; loaded with 2 persons Fuel consumption 12,5 l acc. to guideline DIN 70030, ascertained at 3/4 of max. speed, maximal 110 km/h, unter Zuschlag von 10 % |
| Autor: | adi [ śr sie 17, 2005 12:53 pm ] |
Tak w ogole to witamy
Polecam lekturkę: http://www.w114-115.org.pl/forum/viewtopic.php?t=1719 Pomoże Ci to w odróżnieniu w114 od w115. |
