| Please help with data to set angles of car wheel ! https://forum.w114-115.org.pl/viewtopic.php?f=22&t=11264 |
| Autor: | dobrzan [ pt mar 25, 2005 1:21 pm ] |
| Autor: | MATHIEW [ pt mar 25, 2005 9:19 pm ] |
i dont understand what angels do you mean. if you think about weels geometry here it is: In W115 rear weels are constant ,you can not change their position . front weels depend on mark (I or II). I -before 1973;II after 1973 write somethink about the car and we try to give you corect advice best regards maciej |
| Autor: | kuba [ ndz mar 27, 2005 8:41 pm ] |
Hi Try to do it along below informations: front axle convergence 2...4 [mm] lub 0o15'... 0o35' wheel inclination 0o15'+10'-20' king-pin angle lead 2o20'... 3o king-pin inclination 6o rear axle convergence 0...3 [mm] wheel inclination -0o45' [mm] little "o" means degree I took this details from: http://macmerc.netium.com.pl/index0.html Good luck Kuba |
