| Jak dodać MOCY swojemu MB w DWIE minuty! :)) https://forum.w114-115.org.pl/viewtopic.php?f=1&t=32731 |
Strona 1 z 2 |
| Autor: | manol [ śr mar 26, 2008 12:18 am ] |
| Tytuł: | Jak dodać MOCY swojemu MB w DWIE minuty! :)) |
No właśnie! Dziś zresetowałem pamięć automatycznej skrzyni biegów i ... REWELACJA! Samochód "zyskał" więcej mocy. Lepiej przyspiesza i delikatniej zmienia biegi - super. Poniżej sposób jak to zrobić znaleziony na brytyjskim forum MB http://mbclub.co.uk/forums/index.php ( nie wiem czy mogę podać ten link, w końcu to konkurencja ale właściciele MB nie są małostkowi - prawda? Zapewne jest on znany większości właścicieli MB ale może co poniektórzy "młodzi" posiadacze nie mają o tym pojęcia. " Resetting auto gearbox memory without disconnecting battery.. Found this on the US MB slk forum... was a little scepticle at first until loads of guys reported that their cars were quicker off the line, changed gear at more optimum points etc, so I tried it and it does indeed seem to work! The long way to reset the gearbox memory is to disconnect the battery for 30 minutes - but follow this quick procedure and it can be done in a couple of minutes!! Give it a try yourselves and post the results if it works!! " 1. Get in your car, it doesn't matter if you close the door or not. 2. Turn the key to the on (not start) position, the position just before the starter turns over. 3. Press the gas pedal to the floor with the key in the "on" position. 4. Hold the pedal to the floor for five seconds, then turn the key back to the "off" position (don't remove the key), then release the gas pedal. 5. Wait 2 mins for a full alignment. 6. Drive the car as you always do. Depending on your driving style, this may or may not be a big factor. I do a lot of city driving so I noticed a big change after erasing my history. It is not hard to do this, just follow the instructions - Key on, pedal down 5 secs, key off, pedal up, wait 2 mins. Keep the key in for the entire thing. Seems to work on mine. " Moje swobodne tłumaczenie najważniejszej częsci: 1. Wsiądź do samochodu ( nie jest ważne czy zamkniesz drzwi czy też nie). 2. Przekręć klucz na pozycje (2) zaraz przed uruchomieniem rozrusznika (wszystkie lampki będę zapalone). 3. Pozostawiając klucz w pozycji 2 wciśnij pedał przyspieszenia do podłogi (naciśnij kickdown). 4. Przytrzymaj w tej pozycji pedał przyspieszenia przez co najmniej 5 sekund, nastepnie puść pedał przyspieszenia a potem wyłącz stacyjkę, cofając klucz do pozycji 0 ALE NIE WYJMUJ KLUCZA ze stacyjki przez minimum 2 minuty. Mogę napisać jedno - TO DZIAŁA! PS. Podobno po kilkuset milach "ASB" uczy sie naszego stylu jazdy i znów jest dość niemrawo. Zawsze można powtórzyć powyższą procedurę raz jeszcze. |
| Autor: | boss87 [ śr mar 26, 2008 1:27 am ] |
Pewnie 'działa' od 124 w górę. Co prawda nie posiadam nawet 123 z ASB, ale niby skąd 'komputer' ma wiedzieć czy klucz jest w stacyjce [pkt 4]. Troche mi tutaj zawiewa efektem PLACEBO. |
| Autor: | Popey [ śr mar 26, 2008 9:47 am ] |
Przetesujemy |
| Autor: | BrunoGiamatti [ śr mar 26, 2008 10:12 am ] |
ee juz sie napaliłem że dodam mocy mojemu osiołkowi .. a tu tylko do automatu |
| Autor: | Omen [ śr mar 26, 2008 2:14 pm ] |
O ile się nie myle skrzynie sterowane elektrycznie, czyli od 96r wzwyż są adaptowalne. Pozwole sobie przytoczyć wypowiedź kolegi sewana z forum W202.pl Cytuj: Bo problem polega na tym, że te skrzynie są tzw. "adaptowalne", czyli starają się dopasować charakterystyką do warunków na drodze i stylu jazdy kierowcy.
Czyli, jeśli jedziesz długi czas na trasie bardzo łagodnie, skrzynia dopasowuje się do takiej łagodnej charakterystyki i możesz mieć np. problem z redukcją biegu przy wciśnięciu gazu - trzeba mocniej niż zwykle wcisnąć. I na odwrót, jak będziesz jechał dynamicznie, skrzynia będzie szybciej i przy niższych obrotach redukować biegi niż normalnie. Trzeba się do tego przyzwyczaić. Adaptacje zapisywane są w pamięci komputera pod postacią map - osiągnięcie szczególnego punktu mapy powoduje włączenie danej adaptacji (charakterystyki). Oczywiście, kickdown powoduje opuszczenie danej mapy i skrzynia od tej pory szuka następnego punktu charakterystycznego.... Adaptacje dobrze jest skasować przy okazji przeglądu - skrzynia się "czyści" z głupich pomysłów.... |
| Autor: | Popey [ śr mar 26, 2008 5:32 pm ] |
zrobiłem wszystko wg instrukcji i na pierwszy rzut oka auto chodzi faktycznie lepiej tzn jest "szybciej zbierające się " jutro dalsze testy |
| Autor: | blackmilk [ śr mar 26, 2008 7:22 pm ] |
300seta pali gumy o_O poprostu szok ! nie zajedzie mi to skrzyni ? |
| Autor: | master [ śr mar 26, 2008 8:48 pm ] |
a jak się to ma do spalania ?? PS w 'tiptronicu' jest jakiś tam kickdown ?? |
| Autor: | gizmo [ czw mar 27, 2008 1:48 am ] |
Podejrzewam ze dziala to jedynie w ASB z jakims sterownikiem, a w hydraulicznie sterowanej skrzyni do ktorej ida dwa kabelki od wstecznego to co tam resetowac...? |
| Autor: | Popey [ czw mar 27, 2008 8:20 am ] |
gizmo pisze: Podejrzewam ze dziala to jedynie w ASB z jakims sterownikiem, a w hydraulicznie sterowanej skrzyni do ktorej ida dwa kabelki od wstecznego to co tam resetowac...?
..wiesz placebo placebem ale sprawa wygląda tak , że potrafię sobie wyobrazić że auto jest szybsze jednak z przeniesieniem tego do rzeczywistości jest problem ... a jednak coś sie zmieniło i to na lepsze ... |
| Autor: | gizmo [ czw mar 27, 2008 10:46 am ] |
No nie wiem, ale na chlopski rozum skoro sterownika nie ma, to co mozna zresetowac? olej? |
| Autor: | Martini [ czw mar 27, 2008 3:45 pm ] |
u mnie bez rewelacji. Może coś źle zrobiłem, po operacji, przed odpaleniem wyciągacie kluczyk? ja nie wyciągnąłem, od razu po 2 minutach go uruchomiłem, przejechałem się 100m i raczej sobie wmawiam że jest poprawa. Może w trasie moje 2.2 diesel pokaże pazur
| Autor: | MERCEDES 4 EVER [ czw mar 27, 2008 4:41 pm ] |
Martini pisze: u mnie bez rewelacji. Może coś źle zrobiłem, po operacji, przed odpaleniem wyciągacie kluczyk? ja nie wyciągnąłem, od razu po 2 minutach go uruchomiłem, przejechałem się 100m i raczej sobie wmawiam że jest poprawa. Może w trasie moje 2.2 diesel pokaże pazur
![]() a masz skrzynie 4 czy 5 biegową jak 4 biegową i masz bagnet do samodzielnego sprawdzania oleju to raczej nie da sie zrobic resetu.to dotyczy skrzyn 5 biegowych bez bagnetu-one maja elektronike. |
| Autor: | Martini [ czw mar 27, 2008 10:50 pm ] |
mam 5-cio biegową, mułowatą i leniwą, ale ona taka jest, w pełni sprawna, ale bagnet to chyba też mam (tak mi się wydaje że w tym aucie to było Tu mam od razu pytanko, jak wyczuć różnice pracy ASB przy włączonym W lub S? Co sięwówczas zmienia? Ja nie odczówam w ogóle zmian bawiąc się tym przyciskiem |
| Autor: | master [ czw mar 27, 2008 10:58 pm ] |
spróbuj zrywnie ruszyć na "W" to dostaniesz nobla (chyba, że przycisk nie działa)
| Strona 1 z 2 | Strefa czasowa UTC+01:00 |
