| Czy Koledzy z Warszawy... https://forum.w114-115.org.pl/viewtopic.php?f=1&t=29021 |
| Autor: | Wojtek123 [ wt paź 09, 2007 12:34 pm ] |
| Tytuł: | Czy Koledzy z Warszawy... |
...oglądali może to 126? Nie wiem czy warto wogole sie bujać 120km do Wawy, żeby to ocenić Co sądzicie? Po kiego grzyba sterowanie do kompa, jak nie ma kompa ?
Teoretycznie powinna być welurowa tapicerka VIN WDB1260361A301940 Model 500 SE Chassis 1260361A301940 Engine 117965 12 012836 Transmission 722311 02 878548 Order 0 6 543 26736 Approx. year 1986 Lights BOSCH Cab 01951 Dealer Italy (543) Interior velours grey (978) Paint 199 metallic blue-black (с 01.01.1983) Options 241 left front seat electrically adjustable with memory feature. only applicable to w 210 when installed in conjunction with code 275. (с 01.03.1983) 242 right front seat electrically adjustable with memory feature. only applicable to series w 210 when installed in conjunction with code 275. (с 01.03.1983) 256 rear axle with limited-slip differential (с 01.11.1965 по 30.11.1991) 286 luggage nets on front seat backrests (с 01.01.1962) 341 additional lamp (с 01.09.1982) 412 electric sliding roof with tilting device (с 01.07.1983) 506 outside rear view mirror, left and right, heated (electrically adjustable on the right) (l.h.d.) (с 01.10.1983 по 31.03.1989) outside rear view mirror, right, convex, taxi export version 543 sun visor with vanity mirror, illuminated, left and right (с 01.11.1978) 570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970) front folding armrest w202 - housing at front with armrest 588 automatic climate control and electric window lifters (front and rear doors) (с 01.01.1977) 592 heat-insulating glass, all-around, heated rear window pane (laminated glass), band filter green heat-insulating glass all round, heated rear window, laminated safety glass - tinted strip (с 01.01.1972) 731 wood trim, burred walnut root (с 01.08.1980) 877 reading lamp in the rear (с 01.11.1963) Jeżeli przypadkiem któryś z Kolegów miałby chwilke czasu i chęci i rzucił okiem na niego to byłbym bardzo wdzięczny Dzięki i pozdrawiam, Wojtek. |
| Autor: | Xytras [ wt paź 09, 2007 12:39 pm ] |
Skoro auto nie jest zarejestrowane w kraju, to co robia te tablice na aucie?
| Autor: | Wojtek123 [ wt paź 09, 2007 12:52 pm ] |
Też się zastanawiałem
| Autor: | witek-sec [ wt paź 09, 2007 1:01 pm ] |
Xytras pisze: Skoro auto nie jest zarejestrowane w kraju, to co robia te tablice na aucie?
Jak to mowia : lepszy rydz niz nic . Moze tablice od innego W126 ? Kiedy mieliscie ostatnio wnikliwa kontrole drogowa ? Ze zdjec autko ladne , faktycznie auta z Wloszech maja malo rdzy. Sprawdzone organoleptycznie na swoim aucie. Jak chcesz kupic faktycznie W126, to 120km to nie jest daleko . |
| Autor: | Xytras [ wt paź 09, 2007 1:04 pm ] |
Jezdze po nocach wiec dosyc czesto mnie kasuja A moze inaczej, podobne auto po prostu jest na fotkach ? |
| Autor: | THC [ wt paź 09, 2007 1:42 pm ] |
Może trzyma go pod domem, czy gdzieś na mieście i tak na sztukę szyldy przybił. Różne pomysły ludzie mają. |
