| tłumaczenie z ang. na polski pomoże ktoś? https://forum.w114-115.org.pl/viewtopic.php?f=1&t=27836 |
| Autor: | mercedes124_1987 [ ndz sie 12, 2007 10:59 pm ] |
| Tytuł: | tłumaczenie z ang. na polski pomoże ktoś? |
witam chciałbym żeby to ktoś przetłumaczył bo ja nie daje rady
Y11 >> AC compressor clutch V35 >> AC compressor clutch diode - 10/92 A163>> AC compressor control module B146>> AC compressor RPM sensor M63 >> AC condenser blower motor K129 >> AC condenser blower motor relay R61 >> AC condenser blower motor resistor S342>> AC condenser blower refrigerant pressure switch A63 >> AC control module B53>> AC evaporator temperature sensor S338>> AC refrigerant dual pressure switch S153>> AC refrigerant low pressure switch - 10/92/Cabrio09/92 M7>> AC/heater blower motor S17 >> AC/heater blower motor switch Y137 >> AC/heater recirculation flap solenoid Y150 >> AC/heater valve block - 08/91 31 >> Battery - 30 >> Battery + A118>> Convertible top control module A15 >> Cruise control module X1 >> Data link connector (DLC) A35 >> Engine control module (ECM) Y40 >> Engine coolant blower coupling solenoid - if fitted K12 >> Engine coolant blower motor relay K12 >> Engine coolant blower motor relay - 200D/TD for (A)/(CH) S24 >> Engine coolant blower motor temperature switch - 200D/TD/230/E/TE/CE - 08/91-09/92 Y36 >> Engine coolant heater regulator valve M50 >> Engine coolant pump motor B24 >> Engine coolant temperature (ECT) sensor B75 >> Engine speed (RPM) sensor K20 >> Fuel pump relay - petrol, except 300E/TE/CE-24 - 08/91-09/92 F >> BEZPIECZNIK R6 >> Heater blower speed resistor B34-I >> Heater output temperature sensor - LH B34-II >> Heater output temperature sensor - RH A12 >> Idle speed control (ISC) module - diesel 15 >> Ignition switch - ignition ON B37 >> In-car temperature sensor M51 >> In-car temperature sensor blower A5 >> Instrument panel A11 >> Multifunction control module - 300E/TE/CE-2409/92 B61 >> Outside air temperature sensor pozdrawiam |
| Autor: | Milosh [ ndz sie 12, 2007 11:09 pm ] |
a browar przeslesz poczta czy wyslesz przelewem jego rownowartosc??? Na kiedy Ci to potrzebne??? |
| Autor: | mercedes124_1987 [ ndz sie 12, 2007 11:13 pm ] |
moge wysłać browary albo kase jak wolisz tasz rade tak żeby to było do końca tyg.
| Autor: | maxtro [ pn sie 13, 2007 12:19 am ] |
Jeśli się dorwę to translatora to jutro będziesz miał wszystko, ale muszę płytkę poszukać
| Autor: | beet [ pn sie 13, 2007 1:13 am ] |
Noo, troche rozruszam szare komorki w piekny niedzielny wieczor. Z gory ostrzegam, ze techniczne okreslenia, to nie moja broszka, ale to Ci najwyzej Kolega Milosh poprawi Y11 >> AC compressor clutch - sprzeglo sprezarki klimy V35 >> AC compressor clutch diode - 10/92 - dioda sprzegla sprezarki klimy A163>> AC compressor control module - modul sterujacy sprezarki.. B146>> AC compressor RPM sensor - czujnik obrotow/min sprezarki M63 >> AC condenser blower motor - silnik dmuchawy skraplacza ?? K129 >> AC condenser blower motor relay - przekaznik silnika dmuchawy skraplacza R61 >> AC condenser blower motor resistor - opornik slinika dmuchawy skraplacza S342>> AC condenser blower refrigerant pressure switch - przelacznik cisnieniowy czynnika chlodzacego dmuchawy skraplacza A63 >> AC control module - modul sterujacy klimy B53>> AC evaporator temperature sensor - czujnik temperatury parownika S338>> AC refrigerant dual pressure switch - przelacznik/wylacznik podwojny cisnieniowy czynnika chlodzacego S153>> AC refrigerant low pressure switch - 10/92/Cabrio09/92 - przelacznik/wylacznik niskiego cisnienia czynnika chlodzacego M7>> AC/heater blower motor - silnik dmuchawy nagrzewnicy S17 >> AC/heater blower motor switch - przelacznik/wylacznik dmuchawy nagrzewnicy Y137 >> AC/heater recirculation flap solenoid - cewka klapki recyrkulacyjnej -->pewno do obiegu zamknietego
Y150 >> AC/heater valve block - 08/91 - zawor blokujacy nagrzewnicy 31 >> Battery - - minus akumulatora 30 >> Battery + - plus akumulatora A118>> Convertible top control module - siakis modul sterujacy do kabrioleta (pewnie steruje ogrzewaniem/klima przy otwartym/zamknietym dachu) A15 >> Cruise control module - modul sterujacy (podczas jazdy) X1 >> Data link connector (DLC) - gniazdo diagnostyczne A35 >> Engine control module (ECM) - modul sterujacy silnika Y40 >> Engine coolant blower coupling solenoid - if fitted - chlodzenie silnika - cewka zalaczajaca dmuchawe - jesli jest zamontowana K12 >> Engine coolant blower motor relay - przekaznik silnika dmuchawy K12 >> Engine coolant blower motor relay - 200D/TD for (A)/(CH) przekaznik silnika dmuchawy S24 >> Engine coolant blower motor temperature switch - 200D/TD/230/E/TE/CE - 08/91-09/92 przelacznik temperatury silnika dmuchawy Y36 >> Engine coolant heater regulator valve - zawor regulujacy nagrzewnicy/ogrzewania M50 >> Engine coolant pump motor - silnik pompy? B24 >> Engine coolant temperature (ECT) sensor - czujnik temperatury plynu chlodzacego B75 >> Engine speed (RPM) sensor - czujnik predkosci obrotowej silnika K20 >> Fuel pump relay - petrol, except 300E/TE/CE-24 - 08/91-09/92 - przekaznik pompy paliwa F >> BEZPIECZNIK R6 >> Heater blower speed resistor - opornik predkosci dmuchawy-->nagrzewnicy B34-I >> Heater output temperature sensor - LH - czujnik temperatury wyjsciowej nagrzewnicy LH? B34-II >> Heater output temperature sensor - RH czujnik temperatury wyjsciowej nagrzewnicy RH? A12 >> Idle speed control (ISC) module - diesel - modul regulacji napelnienia na biegu jalowym 15 >> Ignition switch - ignition ON - wlacznik zaplonu - zaplon wlaczony B37 >> In-car temperature sensor - czujnik temperatury wewnetrznej M51 >> In-car temperature sensor blower - czujnik temperatury wewnetrznej dmuchawy A5 >> Instrument panel - zestaw wskaznikow A11 >> Multifunction control module - 300E/TE/CE-2409/92 - wielofunkcyjny modul sterujacy B61 >> Outside air temperature sensor - zewnetrzny czujnik temperatury powietrza Enjoy, z poprawianiem tez
| Autor: | TReneR [ pn sie 13, 2007 9:50 am ] |
Y150 >> AC/heater valve block - 08/91 - zawor blokujacy nagrzewnicy To taczej blok/modul zaworu nagrzewnicy A15 >> Cruise control module - modul sterujacy (podczas jazdy) Modul tempomatu LH - z lewej strony RH - prawej strony A12 >> Idle speed control (ISC) module - diesel - modul regulacji napelnienia na biegu jalowym Modul regulacji predkosci obrotowej biegu jalowego M51 >> In-car temperature sensor blower - czujnik temperatury wewnetrznej dmuchawy Raczej dmuchawa czujnika temperatury wewnetrznej?! |
| Autor: | beet [ pn sie 13, 2007 12:07 pm ] |
Jak na robote po 7 piwkach, to nawet znosnie mi to wyszlo |
| Autor: | Milosh [ pn sie 13, 2007 3:08 pm ] |
Ja osobiscie nie mam juz nic do podania. Piwo lub kase wyslij na adres.......................
Pozdrawiam |
| Autor: | mercedes124_1987 [ pn sie 13, 2007 9:52 pm ] |
to pisać co za to ? kasa piwko
| Autor: | Milosh [ wt sie 14, 2007 1:34 pm ] |
W tej sytuacji ja osobiscie nie mialbym czelnosci domagac sie od Ciebie gratyfikacji (w innej zreszta tez - trza sobie pomagac - tylko jak juz sie mialem zabrac do rzeczy to wszedlem na forum aby wydrukowac sobie text do translacji, patrze i co widze............dobre duszyczki mnie wyreczyly). Moze nastepnym razem bede szybszy
Pozdrawiam |
