| W124 z Katowic - Kto może obejrzeć? https://forum.w114-115.org.pl/viewtopic.php?f=1&t=19617 |
| Autor: | Jarzyn [ pn lip 03, 2006 8:43 pm ] |
Witam! Kto ma niedaleko i mógłby obejrzeć, bo na fotkach wygląda zachęcająco: http://www.otomoto.pl/index.php?sect=show&id=C1259296 VIN WDB1241331B718021 Model 300 D TURBO Chassis 1241331B718021 Engine 603960 12 039478 Transmission 722357 03 680394 Order 0 2 559 20095 Approx. year 1992 Lights BOSCH Wiper BOSCH Cab 00694 Dealer Poland (559) Interior leather mushroom (265) Paint 249 malachite metallic (с 01.01.1990 по 31.12.1996) Options 211 automatic limited slip differential (ASD) (с 01.07.1984) rear axle with automatic limited slip differential (ASD) 240 outside temperature indicator (с 01.03.1982) 280 steering wheel (400 mm dia.) and gearshift lever in leather trim; on W202 390 mm dia. (с 01.05.1984) 404 orthopaedic front seat backrest (multiple contour backrest in model 140), left (с 01.04.1970 по 31.12.1995) 412 electric sliding roof with tilting device (с 01.07.1983) 430 headrests in the rear (с 01.01.1977) 442 airbag in steering wheel (с 01.02.1980 по 31.10.1993) 481 undershields (с 01.10.1962) 538 automatic antenna and front loudspeaker - without radio set (model 500SEC with loudspeaker only) (с 01.10.1989) 540 roller blind, electric, for rear window (с 01.05.1985) 570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970) front folding armrest w202 - housing at front with armrest 588 automatic climate control and electric window lifters (front and rear doors) (с 01.01.1977) 592 heat-insulating glass, all-around, heated rear window pane (laminated glass), band filter green heat-insulating glass all round, heated rear window, laminated safety glass - tinted strip (с 01.01.1972) 600 headlamp wiper/washer (с 01.08.1971) 673 high-capacity battery (с 01.01.1964) 812 rear-mounted loudspeaker (с 01.11.1974) 837 rubber mats on front floor and rear floor; with chassis, front only; with station wagon, including loading floor (с 01.11.1969) Przebieg 430 000 (przy 300 000 robiony remont generalny silnika). 4 opony letnie do wymiany. Do wywalenia: białe kierunki, felgi, gałka zmiany biegów. Właściciel rzeczowy. Jeżeli stan jest taki jak na fotkach i to ja jestem zainteresowany Z góry dzięki za pomoc! Dodano po 10 godzinach. 33 minutach.: Chłopaki pomóżcie. Nikt nie jest z Katowic? |
| Autor: | swinx__wawa [ wt lip 04, 2006 2:56 am ] |
Krzychu zaden problem |
| Autor: | gibber [ wt lip 04, 2006 6:24 am ] |
Biorac pod uwage ze przez 14 lat byl eksploatowany na polskich drogach to bym sobie odpuscil. |
| Autor: | E300TD [ wt lip 04, 2006 8:07 pm ] |
I ten przebieg przy turbo nie wrozy nic dobrego. Zreszta był remontowany.... |
